REST API reference
Creates a key manager
  • externalclient_certificate - client certificate required only when creating an external key manager
  • externalserver_ca_certificates - server ca certificates required only when creating an external key manager
  • externalserversserver - key servers required only when creating an external key manager
  • onboardpassphrase - cluster-wide passphrase required only when creating an onboard key manager # related ontap commands
  • security key-manager external enable
  • security key-manager onboard enable
learn more
  • [doc /security/key-managers](#docs-security-security_key-managers)
POST /security/key-managers
Creates a key manager.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create a key manager.
  • external.client_certificate - Client certificate. Required only when creating an external key manager.
  • external.server_ca_certificates - Server CA certificates. Required only when creating an external key manager.
  • external.servers.server - Key servers. Required only when creating an external key manager.
  • onboard.passphrase - Cluster-wide passphrase. Required only when creating an onboard key manager.
Request Body
Name Type Description
_links
_links
external
external
Configures external key management
onboard
onboard
Configures onboard key management. After configuring onboard key management, save the encrypted configuration data in a safe location so that you can use it if you need to perform a manual recovery operation.
scope
string
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster".
svm
svm
uuid
string
Example request
      "href": "/api/resourcelink"
  "external": {
    "client_certificate": {
    "server_ca_certificates": [
    "servers": [
        "server": "keyserver1.com:5698",
        "timeout": 60,
        "username": "username"
  "onboard": {
    "existing_passphrase": "The cluster password of length 32-256 ASCII characters.",
    "passphrase": "The cluster password of length 32-256 ASCII characters."
  "scope": "string",
  "svm": {
    "name": "svm1",
  "uuid": "string"
Status: 201, Created
_links
_links
num_records
integer
Number of records
records
array[security_key_manager]
    "next": {
  "records": [
      "external": {
        "servers": [
            "timeout": 60,
      "onboard": {
      "scope": "string",
      "svm": {
        "name": "svm1",
      "uuid": "string"
Status: Default
ONTAP Error Response Codes
Error Code Description
65536822
Multitenant key management is not supported in the current cluster version.
65536823
The SVM has key manager already configured.
65536878
External key management cannot be configured as one or more volume encryption keys of the SVM are stored in cluster key management server.
65536824
Multitenant key management is not supported in MetroCluster configurations.
65536038
A maximum of 4 active key servers are allowed.
65536876
External key management requires client and server CA certificates installed and with one or more key servers provided.
65536920
Onboard key manager passphrase length is incorrect.
65536871
Duplicate key management servers exist.
65536834
Failed to get existing key-server details for the SVM.
65536870
Key management servers already configured.
65536821
Certificate is not installed.
65536852
Failed to query supported KMIP protocol versions.
65536895
External key manager cannnot be configured since this cluster is part of a MetroCluster configuration and the partner site of this MetroCluster configuration has onboard key manager configured.
65536916
Onboard key management is only supported for an admin SVM.
65536906
Onboard key management has already been configured at the partner site. Use the CLI to sync the onboard key management with the same passphrase.
65536907
Onboard key management is already configured. Use the CLI to sync any nodes with onboard key management configuration.
65536508
The platform does not support data at rest encryption.
65536310
Failed to setup onboard key management because the MetroCluster peer is unhealthy.
65536900
Onboard key management cannot be configured because this cluster is part of a MetroCluster configuration and the partner site has the external key manager configured.
65536903
Onboard key management has failed to configure on some nodes in the cluster. Use the CLI to sync the onboard key management configuration on failed nodes.
65536214
Failed to generate cluster key encryption key.
65536216
Failed to add cluster key encryption key.
66060338
Failed to establish secure connection for a key management server due to incorrect server_ca certificates.
66060339
Failed to establish secure connection for a key management server due to incorrect client certificates.
66060340
Failed to establish secure connection for a key management server due to Cryptsoft error.
66060341
Failed to establish secure connection for a key management server due to network configuration issues.
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
client_certificate
Client certificate
_links
_links
uuid
string
Certificate UUID
Security certificate object reference
_links
_links
uuid
string
Certificate UUID
key_server_readcreate
_links
_links
server
string
External key server for key management. If no port is provided, a default port of 5696 is used.
timeout
integer
I/O timeout in seconds for communicating with the key server.
username
string
Username credentials for connecting with the key server.
external
client_certificate
client_certificate
Client certificate
array[server_ca_certificates]
The UUIDs of the server CA certificates already installed in the cluster or SVM. The array of certificates are common for all the keyservers per SVM.
servers
array[key_server_readcreate]
The set of external key servers.
onboard
enabled
boolean
Is the onboard key manager enabled?
existing_passphrase
string
The cluster-wide passphrase. This is not audited.
passphrase
string
svm
_links
_links
name
string
The name of the SVM.
uuid
string
_links
_links
external
external
onboard
onboard
scope
string
svm
svm
uuid
string
next
self
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
