Create a key manager
POST /security/key-managers
Creates a key manager.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create a key manager. -
external.client_certificate- Client certificate. Required only when creating an external key manager. -
external.server_ca_certificates- Server CA certificates. Required only when creating an external key manager. -
external.servers.server- Key servers. Required only when creating an external key manager. -
onboard.passphrase- Cluster-wide passphrase. Required only when creating an Onboard Key Manager. -
synchronize- Synchronizes missing onboard keys on any node in the cluster. Required only when creating an Onboard Key Manager at the partner site of a MetroCluster configuration.
Related ONTAP commands
security key-manager external enable -
security key-manager onboard enable -
security key-manager onboard sync
Learn more
return_records |
boolean |
query |
False |
The default is false. If set to true, the records are returned. |
Request Body
| Name | Type | Description |
_links |
external |
Configures external key management |
onboard |
Configures onboard key management. After configuring onboard key management, save the encrypted configuration data in a safe location so that you can use it if you need to perform a manual recovery operation. |
scope |
string |
Set to "svm" for interfaces owned by an SVM. Otherwise, set to "cluster". |
status |
Optional status information on the current state of the key manager indicating if it is fully setup or requires more action. |
svm |
uuid |
string |
volume_encryption |
Indicates whether volume encryption is supported in the cluster. |
Example request
"href": "/api/resourcelink"
"external": {
"client_certificate": {
"server_ca_certificates": [
"servers": [
"connectivity": {
"records": [
"node": {
"name": "node1",
"state": "not_responding"
"server": "keyserver1.com:5698",
"timeout": 60,
"username": "admin"
"is_default_data_at_rest_encryption_disabled": null,
"onboard": {
"existing_passphrase": "The cluster password of length 32-256 ASCII characters.",
"key_backup": "'--------------------------BEGIN BACKUP-------------------------- TmV0QXBwIEtleSBCbG9iAAEAAAAEAAAAcAEAAAAAAAAxBFWWAAAAACEAAAAAAAAA QAAAAAAAAABzDyyVAAAAALI5Jsjvy6gUxnT78KoDKXHYb6sSeraM00quOULY6BeV n6dMFxuErCD1lbERaOQZSuaYy1p8oQHtTEfGMLZM4TYiAAAAAAAAACgAAAAAAAAA 3WTh7gAAAAAAAAAAAAAAAAIAAAAAAAgAZJEIWvdeHr5RCAvHGclo+wAAAAAAAAAA IgAAAAAAAAAoAAAAAAAAAEOTcR0AAAAAAAAAAAAAAAACAAAAAAAJAGr3tJA/LRzU QRHwv+1aWvAAAAAAAAAAACQAAAAAAAAAgAAAAAAAAADV1Vd/AAAAAMFM9Q229Bhp mDaTSdqku5DCd8wG+fOZSr4bx4JT5WHvV/r5gJnXDQQAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAABOZXRBcHAgS2V5IEJsb2IA AQAAAAMAAAAYAQAAAAAAALgePkcAAAAAIgAAAAAAAAAoAAAAAAAAAEOTcR0AAAAA AAAAAAAAAAACAAAAAAAJAGr3tJA/LRzUQRHwv+1aWvAAAAAAAAAAACIAAAAAAAAA KAAAAAAAAACIlCHZAAAAAAAAAAAAAAAAAgAAAAAAAQCafcabsxRXMM7gxhLRrzxh AAAAAAAAAAAkAAAAAAAAAIAAAAAAAAAA2JjQBQAAAACt4IqXcNpVggahl0axLsN4 yQjnNVKWY7mANB29O42hI7b70DTGCTaVAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAE5ldEFwcCBLZXkgQmxvYgABAAAAAwAAABgBAAAAAAAA 7sbaoQAAAAAiAAAAAAAAACgAAAAAAAAAQ5NxHQAAAAAAAAAAAAAAAAIAAAAAAAkA ave0kD8tHNRBEfC/7Vpa8AAAAAAAAAAAIgAAAAAAAAAoAAAAAAAAALOHfWkAAAAA AAAAAAAAAAACAAAAAAABAMoI9UxrHOGthQm/CB+EHdAAAAAAAAAAACQAAAAAAAAA gAAAAAAAAACnMmUtAAAAAGVk8AtPzENFgsGdsFvnmucmYrlQCsFew0HDSFKaZqK6 W8IEVzBAhPoAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA AAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAAA ---------------------------END BACKUP---------------------------'",
"passphrase": "The cluster password of length 32-256 ASCII characters."
"scope": "string",
"status": {
"code": 346758,
"message": "This cluster is part of a MetroCluster configuration. Use the REST API POST method security/key_managers/ with the synchronize option and the same passphrase on the partner cluster before proceeding with any key manager operations. Failure to do so could lead to switchover or switchback failure."
"svm": {
"name": "svm1",
"uuid": "string",
"volume_encryption": {
"code": 346758,
"message": "No platform support for volume encryption in following nodes - node1, node2."
Status: 201, Created
_links |
num_records |
integer |
Number of records |
records |
array[security_key_manager] |
"next": {
"records": [
"external": {
"servers": [
"connectivity": {
"records": [
"node": {
"name": "node1",
"timeout": 60,
"username": "admin"
"onboard": {
"scope": "string",
"status": {
"code": 346758,
"svm": {
"name": "svm1",
"uuid": "string",
"code": 346758,
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65536038 |
A maximum of 4 active key servers are allowed. |
65536214 |
Failed to generate cluster key encryption key. |
65536216 |
Failed to add cluster key encryption key. |
65536310 |
Failed to setup onboard key management because the MetroCluster peer is unhealthy. |
65536508 |
The platform does not support data at rest encryption. |
65536821 |
The certificate is not installed. |
65536822 |
Multitenant key management is not supported in the current cluster version. |
65536823 |
The SVM has key manager already configured. |
65536824 |
Multitenant key management is not supported in MetroCluster configurations. |
65536834 |
Failed to get existing key-server details for the SVM. |
65536852 |
Failed to query supported KMIP protocol versions. |
65536870 |
Key management servers already configured. |
65536871 |
Duplicate key management servers exist. |
65536876 |
External key management requires client and server CA certificates installed and with one or more key servers provided. |
65536878 |
External key management cannot be configured as one or more volume encryption keys of the SVM are stored in cluster key management server. |
65536895 |
External key manager cannnot be configured since this cluster is part of a MetroCluster configuration and the partner site of this MetroCluster configuration has Onboard Key Manager configured. |
65536900 |
Onboard key management cannot be configured because this cluster is part of a MetroCluster configuration and the partner site has the external key manager configured. |
65536903 |
Onboard key management has failed to configure on some nodes in the cluster. Use the CLI to sync the onboard key management configuration on failed nodes. |
65536906 |
Onboard key management has already been configured at the partner site. Use the CLI to sync the onboard key management with the same passphrase. |
65536907 |
Onboard key management is already configured. Use the CLI to sync any nodes with onboard key management configuration. |
65536916 |
Onboard key management is only supported for an admin SVM. |
65536920 |
The Onboard Key Manager passphrase length is incorrect. |
65537240 |
The Onboard Key Manager passphrase must be provided when performing a POST/synchronize operation. |
65537241 |
The Onboard Key Manager existing_passphrase must not be provided when performing a POST/synchronize operation. |
65537244 |
Unable to sync/create Onboard Key Manager on the local cluster; Onboard Key Manager is already configured on the cluster. |
65537245 |
Unable to sync/create Onboard Key Manager on the local cluster; Onboard Key Manager is not configured on the partner cluster. |
65537246 |
Unable to sync/create Onboard Key Manager on local cluster. This cluster is not part of a MetroCluster configuration. |
66060338 |
Failed to establish secure connection for a key management server due to incorrect server_ca certificates. |
66060339 |
Failed to establish secure connection for a key management server due to incorrect client certificates. |
66060340 |
Failed to establish secure connection for a key management server due to Cryptsoft error. |
66060341 |
Failed to establish secure connection for a key management server due to network configuration issues. |
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
client_certificate
Client certificate
_links |
uuid |
string |
Certificate UUID |
_links |
uuid |
string |
Certificate UUID |
self_link
self |
node
_links |
name |
string |
uuid |
string |
key_server_state
The state of the key server for a specific node.
node |
state |
string |
Key server connectivity state |
connectivity
This property returns the key server connectivity state on all nodes of the cluster. The state is returned for a node only if the connectivity is not in an available state on that node.
This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the fields query parameter or GET for all advanced properties is enabled.
cluster_availability |
boolean |
Set to true when key server connectivity state is available on all nodes of the cluster. |
records |
array[key_server_state] |
An array of key server connectivity states for each node. |
key_server_readcreate
_links |
connectivity |
This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
server |
string |
External key server for key management. If no port is provided, a default port of 5696 is used. |
timeout |
integer |
I/O timeout in seconds for communicating with the key server. |
username |
string |
Username credentials for connecting with the key server. |
external
client_certificate |
Client certificate |
server_ca_certificates |
array[server_ca_certificates] |
The UUIDs of the server CA certificates already installed in the cluster or SVM. The array of certificates are common for all the keyservers per SVM. |
servers |
array[key_server_readcreate] |
The set of external key servers. |
onboard
enabled |
boolean |
Is the onboard key manager enabled? |
existing_passphrase |
string |
The cluster-wide passphrase. This is not audited. |
key_backup |
string |
Backup of the onboard key manager's key hierarchy. It is required to save this backup after configuring the onboard key manager to help in the recovery of the cluster in case of catastrophic failures. |
passphrase |
string |
synchronize |
boolean |
Synchronizes missing onboard keys on any node in the cluster. If a node is added to a cluster that has onboard key management configured, the synchronize operation needs to be performed in a PATCH operation. In a MetroCluster configuration, if onboard key management is enabled on one site, then the synchronize operation needs to be run as a POST operation on the remote site providing the same passphrase. |
status
code |
integer |
Code corresponding to the status message. Returns 0 if the setup is complete. This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
message |
string |
Current state of the key manager indicating any additional steps to perform to finish the setup. This is an advanced property; there is an added cost to retrieving its value. The property is not populated for either a collection GET or an instance GET unless it is explicitly requested using the |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
volume_encryption
code |
integer |
Code corresponding to the status message. Returns a 0 if volume encryption is supported in all nodes of the cluster. |
message |
string |
Reason for not supporting volume encryption. |
supported |
boolean |
Set to true when volume encryption support is available on all nodes of the cluster. |
_links |
external |
onboard |
scope |
string |
status |
svm |
uuid |
string |
volume_encryption |
_links
next |
self |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
