REST API reference
Protocols s3 services svm.uuid buckets s3_bucket.uuid rules endpoint overview
Overview
An S3 bucket lifecycle management rule is a list of objects. Each rule defines a set of actions to be performed on the object within the bucket.
Adding a lifecycle management rule on a S3 bucket under an SVM
# The API:
/api/protocols/s3/services/{svm.uuid}/buckets/{uuid}/rules
# The call:
curl -iku admin:netapp1! -X POST "https://<mgmt-ip>/api/protocols/s3/services/259b4e78-2893-67ea-9785-890456bbbec4/buckets/259b4e46-2893-67ea-9145-909456bbbec4/rules?return_timeout=0&return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"name\": \"rule1\", \"expiration\" : { \"object_age_days\" : \"1000\" }, \"abort_incomplete_multipart_upload\" : { \"after_initiation_days\" : 200 } , \"object_filter\": { \"prefix\" : \"obj1*/\" ,  \"size_greater_than\" : \"1000\" } }"
# The response:
HTTP/1.1 202 Accepted
Date: Fri, 30 Novemeber 2022 11:22:14 GMT
Server: libzapid-httpd
X-Content-Type-Options: nosniff
Cache-Control: no-cache,no-store,must-revalidate
Location: /api/protocols/s3/services/259b4e78-2893-67ea-9785-890456bbbec4/buckets/259b4e46-2893-67ea-9145-909456bbbec4/rules?name=bucket-4
Content-Length: 353
"job": {
  "uuid": "2e880171-7e16-11e9-bfdc-0050568ea123",
      "href": "/api/cluster/jobs/2e880171-7e16-11e9-bfdc-0050568ea123"
Updating a lifecycle management rule on a S3 bucket under an SVM
# The call:
curl -iku admin:netapp1! -X PATCH "https://<mgmt-ip>/api/protocols/s3/services/259b4e78-2893-67ea-9785-890456bbbec4/buckets/259b4e46-2893-67ea-9145-909456bbbec4/rules/rule1?return_timeout=0&return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"expiration\" : { \"object_age_days\" : \"3000\" }, \"abort_incomplete_multipart_upload\" : { \"after_initiation_days\" : \"5000\" } }"
# The response:
Content-Length: 353
"job": {
  "uuid": "2e880171-7e16-11e9-bfdc-0050568ea124",
      "href": "/api/cluster/jobs/2e880171-7e16-11e9-bfdc-0050568ea124"
Deleting a lifecycle management rule on a S3 bucket under an SVM
# The call:
curl -X DELETE "https://<mgmt-ip>/api/protocols/s3/services/259b4e78-2893-67ea-9785-890456bbbec4/buckets/259b4e46-2893-67ea-9145-909456bbbec4/rules/rule1"  -H "accept: application/json"
To delete an action within a rule, pass null inside the action-object.
# The call:
curl -iku admin:netapp1! -X PATCH "https://<mgmt-ip>/api/protocols/s3/services/259b4e78-2893-67ea-9785-890456bbbec4/buckets/259b4e46-2893-67ea-9145-909456bbbec4/rules/rule1?return_timeout=0&return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"expiration\" : null }"
# The response:
Content-Length: 353
"job": {
