Protocols S3 services svm.uuid buckets s3_bucket.uuid rules endpoint overview
Overview
An S3 bucket lifecycle management rule is a list of objects. Each rule defines a set of actions to be performed on the object within the bucket.
Adding a lifecycle management rule on a S3 bucket under an SVM
# The API: /api/protocols/s3/services/{svm.uuid}/buckets/{uuid}/rules # The call: curl -iku admin:<password> -X POST "https://<mgmt-ip>/api/protocols/s3/services/259b4e78-2893-67ea-9785-890456bbbec4/buckets/259b4e46-2893-67ea-9145-909456bbbec4/rules?return_timeout=0&return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"name\": \"rule1\", \"expiration\" : { \"object_age_days\" : \"1000\" }, \"abort_incomplete_multipart_upload\" : { \"after_initiation_days\" : 200 } , \"object_filter\": { \"prefix\" : \"obj1*/\" , \"size_greater_than\" : \"1000\" } }" # The response: HTTP/1.1 202 Accepted Date: Fri, 30 November 2022 11:22:14 GMT Server: libzapid-httpd X-Content-Type-Options: nosniff Cache-Control: no-cache,no-store,must-revalidate Location: /api/protocols/s3/services/259b4e78-2893-67ea-9785-890456bbbec4/buckets/259b4e46-2893-67ea-9145-909456bbbec4/rules?name=bucket-4 Content-Length: 353 Content-Type: application/json { "job": { "uuid": "2e880171-7e16-11e9-bfdc-0050568ea123", "_links": { "self": { "href": "/api/cluster/jobs/2e880171-7e16-11e9-bfdc-0050568ea123" } } } }
Updating a lifecycle management rule on a S3 bucket under an SVM
# The call: curl -iku admin:<password> -X PATCH "https://<mgmt-ip>/api/protocols/s3/services/259b4e78-2893-67ea-9785-890456bbbec4/buckets/259b4e46-2893-67ea-9145-909456bbbec4/rules/rule1?return_timeout=0&return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"expiration\" : { \"object_age_days\" : \"3000\" }, \"abort_incomplete_multipart_upload\" : { \"after_initiation_days\" : \"5000\" } }" # The response: HTTP/1.1 202 Accepted Date: Fri, 30 November 2022 11:22:14 GMT Server: libzapid-httpd X-Content-Type-Options: nosniff Cache-Control: no-cache,no-store,must-revalidate Location: /api/protocols/s3/services/259b4e78-2893-67ea-9785-890456bbbec4/buckets/259b4e46-2893-67ea-9145-909456bbbec4/rules?name=bucket-4 Content-Length: 353 Content-Type: application/json { "job": { "uuid": "2e880171-7e16-11e9-bfdc-0050568ea124", "_links": { "self": { "href": "/api/cluster/jobs/2e880171-7e16-11e9-bfdc-0050568ea124" } } } }
Deleting a lifecycle management rule on a S3 bucket under an SVM
# The call: curl -X DELETE "https://<mgmt-ip>/api/protocols/s3/services/259b4e78-2893-67ea-9785-890456bbbec4/buckets/259b4e46-2893-67ea-9145-909456bbbec4/rules/rule1" -H "accept: application/json"
To delete an action within a rule, pass null inside the action-object.
# The call: curl -iku admin:<password> -X PATCH "https://<mgmt-ip>/api/protocols/s3/services/259b4e78-2893-67ea-9785-890456bbbec4/buckets/259b4e46-2893-67ea-9145-909456bbbec4/rules/rule1?return_timeout=0&return_records=true" -H "accept: application/json" -H "Content-Type: application/json" -d "{ \"expiration\" : null }" # The response: HTTP/1.1 202 Accepted Date: Fri, 30 November 2022 11:22:14 GMT Server: libzapid-httpd X-Content-Type-Options: nosniff Cache-Control: no-cache,no-store,must-revalidate Location: /api/protocols/s3/services/259b4e78-2893-67ea-9785-890456bbbec4/buckets/259b4e46-2893-67ea-9145-909456bbbec4/rules?name=bucket-4 Content-Length: 353 Content-Type: application/json { "job": { "uuid": "2e880171-7e16-11e9-bfdc-0050568ea124", "_links": { "self": { "href": "/api/cluster/jobs/2e880171-7e16-11e9-bfdc-0050568ea124" } } } }
