Retrieve HTTP proxy configurations for all SVMs and cluster IPspaces
Retrieves HTTP proxy configurations for all SVMs and cluster IPspaces to review and manage proxy settings efficiently across your network.
HTTP method and endpoint
GET /network/http-proxy
Introduced in
ONTAP 9.7
Usage notes
Retrieves the HTTP proxy configurations of all the SVMs and Cluster IPspaces.
Related ONTAP commands
vserver http-proxy show
scope |
string |
query |
False |
Filter by scope |
ipspace.uuid |
string |
query |
False |
Filter by ipspace.uuid |
ipspace.name |
string |
query |
False |
Filter by ipspace.name |
authentication_enabled |
boolean |
query |
False |
Filter by authentication_enabled
uuid |
string |
query |
False |
Filter by uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
server |
string |
query |
False |
Filter by server |
port |
integer |
query |
False |
Filter by port
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of HTTP proxy records |
records |
array[network_http_proxy] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"ipspace": {
"name": "Default",
"port": 3128,
"scope": "string",
"server": "string",
"svm": {
"name": "svm1",
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input. This is mutually exclusive with SVM during POST and PATCH.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
This is mutually exclusive with IPspace during POST and PATCH.
_links |
name |
string |
uuid |
string |
network_http_proxy
_links |
boolean |
Specifies whether or not authentication with the HTTP proxy server is enabled. |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input. This is mutually exclusive with SVM during POST and PATCH. |
port |
integer |
The port number on which the HTTP proxy service is configured on the proxy server. |
scope |
string |
Set to “svm” for HTTP proxy owned by an SVM. Otherwise, set to "cluster". |
server |
string |
Fully qualified domain name (FQDN) or IP address of the HTTP proxy server. |
svm |
This is mutually exclusive with IPspace during POST and PATCH. |
uuid |
string |
The UUID that uniquely identifies the HTTP proxy. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
