Retrieve HTTP proxy configurations for all SVMs and cluster IPspaces
Retrieves the HTTP proxy configurations for all SVMs and Cluster IPspaces to assess and manage network proxy settings effectively.
HTTP method and endpoint
GET /network/http-proxy
Introduced in
ONTAP 9.7
Usage notes
Retrieves the HTTP proxy configurations of all the SVMs and Cluster IPspaces.
Related ONTAP commands
vserver http-proxy show
scope |
string |
query |
False |
Filter by scope |
authentication_enabled |
boolean |
query |
False |
Filter by authentication_enabled
server |
string |
query |
False |
Filter by server |
uuid |
string |
query |
False |
Filter by uuid |
port |
integer |
query |
False |
Filter by port |
svm.uuid |
string |
query |
False |
Filter by svm.uuid |
svm.name |
string |
query |
False |
Filter by svm.name |
ipspace.uuid |
string |
query |
False |
Filter by ipspace.uuid |
ipspace.name |
string |
query |
False |
Filter by ipspace.name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of HTTP proxy records |
records |
array[network_http_proxy] |
"next": {
"href": "/api/resourcelink"
"records": [
"ipspace": {
"name": "exchange",
"port": "3128",
"scope": "string",
"server": "string",
"svm": {
"name": "svm1",
"uuid": "string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input.
_links |
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
_links |
name |
string |
The name of the SVM. |
uuid |
string |
network_http_proxy
_links |
boolean |
Specifies whether or not authentication with the HTTP proxy server is enabled. |
ipspace |
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input. |
port |
integer |
The port number on which the HTTP proxy service is configured on the proxy server. |
scope |
string |
Set to “svm” for HTTP proxy owned by an SVM. Otherwise, set to "cluster". |
server |
string |
Fully qualified domain name (FQDN) or IP address of the HTTP proxy server. |
svm |
uuid |
string |
The UUID that uniquely identifies the HTTP proxy. |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
