REST API reference
Retrieve HTTP proxy configurations for all SVMs and cluster IPspaces
Retrieves the HTTP proxy configurations for all SVMs and cluster IPspaces. Access this information to manage and audit proxy settings across your network environments.
HTTP method and endpoint
GET /network/http-proxy
Introduced in
ONTAP 9.7
Usage notes
Retrieves the HTTP proxy configurations of all the SVMs and Cluster IPspaces.
  • vserver http-proxy show
svm.uuid
string
query
False
Filter by svm.uuid
svm.name
string
query
False
Filter by svm.name
scope
string
query
False
Filter by scope
server
string
query
False
Filter by server
port
integer
query
False
Filter by port
  • Max value: 65535
  • Min value: 1
uuid
string
query
False
Filter by uuid
ipspace.name
string
query
False
Filter by ipspace.name
ipspace.uuid
string
query
False
Filter by ipspace.uuid
authentication_enabled
boolean
query
False
Filter by authentication_enabled
  • Introduced in: 9.9
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Max value: 120
  • Min value: 0
  • Default value: 15
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of HTTP proxy records
records
array[network_http_proxy]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "ipspace": {
        "name": "Default",
      "port": 3128,
      "scope": "string",
      "server": "string",
      "svm": {
        "name": "svm1",
      "uuid": "string"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name is supplied on input. This is mutually exclusive with SVM during POST and PATCH.
_links
_links
name
string
IPspace name
uuid
string
IPspace UUID
svm
This is mutually exclusive with IPspace during POST and PATCH.
_links
_links
name
string
uuid
string
network_http_proxy
_links
_links
boolean
Specifies whether or not authentication with the HTTP proxy server is enabled.
ipspace
ipspace
port
integer
The port number on which the HTTP proxy service is configured on the proxy server.
scope
string
Set to “svm” for HTTP proxy owned by an SVM. Otherwise, set to "cluster".
server
string
Fully qualified domain name (FQDN) or IP address of the HTTP proxy server.
svm
svm
uuid
string
The UUID that uniquely identifies the HTTP proxy.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
