REST API reference
Retrieve the FPolicy persistent store configurations for an SVM
Retrieves the FPolicy persistent store configurations for a specific SVM to examine the current settings and make informed management decisions.
HTTP method and endpoint
GET /protocols/fpolicy/{svm.uuid}/persistent-stores
Introduced in
ONTAP 9.14
Usage notes
Retrieves FPolicy Persistent Store configurations for a specified SVM.
  • fpolicy persistent-store show
size
integer
query
False
Filter by size
  • Introduced in: 9.15
autosize_mode
string
query
False
Filter by autosize_mode
name
string
query
False
Filter by name
volume
string
query
False
Filter by volume
svm.uuid
string
path
True
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[fpolicy_persistent_store]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "autosize_mode": "string",
      "name": "ps1",
      "size": "100M",
      "svm": {
        "uuid": "string"
      "volume": "psvol"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
svm
uuid
string
SVM UUID
The information that an FPolicy process needs in order to configure a Persistent Store.
autosize_mode
string
Autosize mode for the volume. grow ‐ Volume automatically grows in response to the amount of space used. grow_shrink ‐ Volume grows or shrinks in response to the amount of space used. off ‐ Autosizing of the volume is disabled.
name
string
The name specified for the FPolicy Persistent Store.
size
integer
The size of the Persistent Store volume, in bytes.
svm
svm
volume
string
The specified volume to store the events for the FPolicy Persistent Store.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
