Retrieve the FPolicy persistent store configurations for an SVM
Retrieves the FPolicy persistent store configurations for a specified SVM to manage and analyze file policy settings effectively.
HTTP method and endpoint
GET /protocols/fpolicy/{svm.uuid}/persistent-stores
Introduced in
ONTAP 9.14
Related ONTAP commands
fpolicy persistent-store show
size |
integer |
query |
False |
Filter by size
volume |
string |
query |
False |
Filter by volume |
name |
string |
query |
False |
Filter by name |
autosize_mode |
string |
query |
False |
Filter by autosize_mode
svm.uuid |
string |
path |
True |
UUID of the SVM to which this object belongs. |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[fpolicy_persistent_store] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"autosize_mode": "string",
"name": "ps1",
"size": "100M",
"svm": {
"uuid": "string"
"volume": "psvol"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
svm
uuid |
string |
SVM UUID |
The information that an FPolicy process needs in order to configure a Persistent Store.
autosize_mode |
string |
Autosize mode for the volume. grow ‐ Volume automatically grows in response to the amount of space used. grow_shrink ‐ Volume grows or shrinks in response to the amount of space used. off ‐ Autosizing of the volume is disabled. |
name |
string |
The name specified for the FPolicy Persistent Store. |
size |
integer |
The size of the Persistent Store volume, in bytes. |
svm |
volume |
string |
The specified volume to store the events for the FPolicy Persistent Store. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
