Retrieve an export policy rule
Retrieves an export policy rule to view its current configuration and settings. This helps you manage and verify access permissions for NFS clients in your storage environment.
HTTP method and endpoint
GET /protocols/nfs/export-policies/{policy.id}/rules/{index}
Introduced in
ONTAP 9.6
Usage notes
Related ONTAP commands
vserver export-policy rule show
Learn more
policy.id |
integer |
path |
True |
Export Policy ID |
index |
integer |
path |
True |
Export Rule Index |
fields |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
allow_device_creation |
boolean |
Specifies whether or not device creation is allowed. |
allow_suid |
boolean |
Specifies whether or not SetUID bits in SETATTR Op is to be honored. |
anonymous_user |
string |
User ID To Which Anonymous Users Are Mapped. |
chown_mode |
string |
Specifies who is authorized to change the ownership mode of a file. |
clients |
array[export_clients] |
Array of client matches |
index |
integer |
Index of the rule within the export policy. |
ntfs_unix_security |
string |
NTFS export UNIX security options. |
policy |
protocols |
array[string] |
ro_rule |
array[string] |
Authentication flavors that the read-only access rule governs |
rw_rule |
array[string] |
Authentication flavors that the read/write access rule governs |
superuser |
array[string] |
Authentication flavors that the superuser security type governs |
svm |
"href": "/api/resourcelink"
"anonymous_user": "string",
"chown_mode": "string",
"clients": [
"match": "0.0.0.0/0"
"ntfs_unix_security": "string",
"policy": {
"name": "string"
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
"svm": {
"name": "svm1",
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
export_clients
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
policy
id |
integer |
Export policy ID |
name |
string |
Export policy name |
svm
_links |
name |
string |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
