REST API reference
Retrieve an export policy rule
GET /protocols/nfs/export-policies/{policy.id}/rules/{index}
Introduced In: 9.6
Retrieves an export policy rule
  • vserver export-policy rule show
policy.id
integer
path
True
Export Policy ID
index
integer
path
True
Export Rule Index
fields
array[string]
query
False
Specify the fields to return.
Status: 200, Ok
Name Type Description
_links
_links
allow_device_creation
boolean
Specifies whether or not device creation is allowed.
allow_suid
boolean
Specifies whether or not SetUID bits in SETATTR Op is to be honored.
anonymous_user
string
User ID To Which Anonymous Users Are Mapped.
chown_mode
string
Specifies who is authorized to change the ownership mode of a file.
clients
array[export_clients]
Array of client matches
index
integer
Index of the rule within the export policy.
ntfs_unix_security
string
NTFS export UNIX security options.
policy
policy
protocols
array[string]
ro_rule
array[string]
Authentication flavors that the read-only access rule governs
rw_rule
array[string]
Authentication flavors that the read/write access rule governs
superuser
array[string]
Authentication flavors that the superuser security type governs
svm
svm
      "href": "/api/resourcelink"
  "anonymous_user": "string",
  "chown_mode": "string",
  "clients": [
      "match": "0.0.0.0/0"
  "ntfs_unix_security": "string",
  "policy": {
    "name": "string"
  "protocols": [
    "string"
  "ro_rule": [
    "string"
  "rw_rule": [
    "string"
  "superuser": [
    "string"
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
Error Code Description
262197
The value provided is invalid for the field
6691623
User is not authorized
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
export_clients
match
string
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
  • As a hostname; for instance, host1
  • As an IPv4 address; for instance, 10.1.12.24
  • As an IPv6 address; for instance, fd20:8b1e:b255:4071::100:1
  • As an IPv4 address with a subnet mask expressed as a number of bits; for instance, 10.1.12.0/24
  • As an IPv6 address with a subnet mask expressed as a number of bits; for instance, fd20:8b1e:b255:4071::/64
  • As an IPv4 address with a network mask; for instance, 10.1.16.0/255.255.255.0
  • As a netgroup, with the netgroup name preceded by the @ character; for instance, @eng
  • As a domain name preceded by the . character; for instance, .example.com
policy
id
integer
Export policy ID
name
string
Export policy name
svm
_links
_links
name
string
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
