Retrieve an export policy rule
GET /protocols/nfs/export-policies/{policy.id}/rules/{index}
Introduced In: 9.6
Retrieves an export policy rule
Related ONTAP commands
vserver export-policy rule show
Learn more
policy.id  |
integer  |
path  |
True  |
Export Policy ID  |
index  |
integer  |
path  |
True  |
Export Rule Index  |
fields  |
array[string]  |
query  |
False  |
Specify the fields to return.  |
Status: 200, Ok
| Name | Type | Description |
_links  |
allow_device_creation  |
boolean  |
Specifies whether or not device creation is allowed.  |
allow_suid  |
boolean  |
Specifies whether or not SetUID bits in SETATTR Op is to be honored.  |
anonymous_user  |
string  |
User ID To Which Anonymous Users Are Mapped.  |
chown_mode  |
string  |
Specifies who is authorized to change the ownership mode of a file.  |
clients  |
array[export_clients]  |
Array of client matches  |
index  |
integer  |
Index of the rule within the export policy.  |
ntfs_unix_security  |
string  |
NTFS export UNIX security options.  |
policy  |
protocols  |
array[string]  |
ro_rule  |
array[string]  |
Authentication flavors that the read-only access rule governs  |
rw_rule  |
array[string]  |
Authentication flavors that the read/write access rule governs  |
superuser  |
array[string]  |
Authentication flavors that the superuser security type governs  |
svm  |
SVM, applies only to SVM-scoped objects.  |
      "href": "/api/resourcelink"
  "anonymous_user": "string",
  "chown_mode": "string",
  "clients": [
      "match": "0.0.0.0/0"
  "ntfs_unix_security": "string",
  "policy": {
    "name": "string"
  "protocols": [
    "string"
  "ro_rule": [
    "string"
  "rw_rule": [
    "string"
  "superuser": [
    "string"
  "svm": {
    "name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
262197  |
The value provided is invalid for the field  |
6691623  |
User is not authorized  |
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
export_clients
match  |
string  |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
policy
id  |
integer  |
Export policy ID  |
name  |
string  |
Export policy name  |
svm
_links  |
name  |
string  |
The name of the SVM. This field cannot be specified in a PATCH method.  |
uuid  |
string  |
The unique identifier of the SVM. This field cannot be specified in a PATCH method.  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
