Retrieve an export policy rule
GET /protocols/nfs/export-policies/{policy.id}/rules/{index}
Retrieves an export policy rule
Related ONTAP commands
vserver export-policy rule show
Learn more
Name | Type | In | Required | Description |
policy.id |
integer |
path |
True |
Export Policy ID |
index |
integer |
path |
True |
Export Rule Index |
fields |
array[string] |
query |
False |
Status: 200, Ok
Name | Type | Description |
_links |
anonymous_user |
string |
User ID To Which Anonymous Users Are Mapped. |
clients |
array[export_client] |
Array of client matches |
index |
integer |
Index of the rule within the export policy. |
protocols |
array[string] |
ro_rule |
array[string] |
Authentication flavors that the read-only access rule governs |
rw_rule |
array[string] |
Authentication flavors that the read/write access rule governs |
superuser |
array[string] |
Authentication flavors that the superuser security type governs |
"href": "/api/resourcelink"
"anonymous_user": "string",
"clients": [
"match": "0.0.0.0/0"
"index": 0,
"protocols": [
"string"
"ro_rule": [
"string"
"rw_rule": [
"string"
"superuser": [
"string"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
export_client
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
