REST API reference
Retrieve privilege details of the specified role
GET /security/roles/{owner.uuid}/{name}/privileges
Introduced In: 9.6
Retrieves privilege details of the specified role.
  • security login rest-role show
  • security login role show
owner.uuid
string
path
True
Role owner UUID
name
string
path
True
Role name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[role_privilege]
    "next": {
      "href": "/api/resourcelink"
  "num_records": 1,
  "records": [
      "access": "all",
      "path": "volume move start",
      "query": "-vserver vs1|vs2|vs3 -destination-aggregate aggr1|aggr2"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
role_privilege
A tuple containing a REST endpoint or a command/command directory path and the access level assigned to that endpoint or command/command directory. If the "path" attribute refers to a command/command directory path, the tuple could additionally contain an optional query. The REST endpoint can be a resource-qualified endpoint. At present, the only supported resource-qualified endpoints are the following
Snapshots APIs
  • /api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
  • /api/storage/volumes/{volume.uuid}/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/clients
  • /api/storage/volumes/{volume.uuid}/top-metrics/directories
  • /api/storage/volumes/{volume.uuid}/top-metrics/files
  • /api/storage/volumes/{volume.uuid}/top-metrics/users
  • /api/svm/svms/{svm.uuid}/top-metrics/clients
  • /api/svm/svms/{svm.uuid}/top-metrics/directories
  • /api/svm/svms/{svm.uuid}/top-metrics/files
  • /api/svm/svms/{svm.uuid}/top-metrics/users
  • /api/protocols/s3/services/{svm.uuid}/users
In the above APIs, wildcard character * could be used in place of {volume.uuid} or {svm.uuid} to denote all volumes or all SVMs, depending upon whether the REST endpoint references volumes or SVMs. The {volume.uuid} refers to the -instance-uuid field value in the "volume show" command output at diagnostic privilege level. It can also be fetched through REST endpoint /api/storage/volumes.
_links
_links
access
string
Access level for the REST endpoint or command/command directory path. If it denotes the access level for a command/command directory path, the only supported enum values are 'none','readonly' and 'all'.
path
string
Either of REST URI/endpoint OR command/command directory path.
query
string
Optional attribute that can be specified only if the "path" attribute refers to a command/command directory path. The privilege tuple implicitly defines a set of objects the role can or cannot access at the specified access level. The query further reduces this set of objects to a subset of objects that the role is allowed to access. The query attribute must be applicable to the command/command directory specified by the "path" attribute. It is defined using one or more parameters of the command/command directory path specified by the "path" attribute.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
