Retrieve privilege details of the specified role
Accesses detailed privilege information for a specific role, helping you manage security configurations effectively.
HTTP method and endpoint
GET /security/roles/{owner.uuid}/{name}/privileges
Introduced in
ONTAP 9.6
Usage notes
Retrieves privilege details of the specified role.
Related ONTAP commands
security login rest-role show -
security login role show
owner.uuid |
string |
path |
True |
Role owner UUID |
name |
string |
path |
True |
Role name |
fields |
array[string] |
query |
False |
max_records |
integer |
query |
False |
return_records |
boolean |
query |
False |
return_timeout |
integer |
query |
False |
order_by |
array[string] |
query |
False |
Status: 200, Ok
| Name | Type | Description |
_links |
num_records |
integer |
Number of records |
records |
array[role_privilege] |
"next": {
"href": "/api/resourcelink"
"num_records": 1,
"records": [
"access": "all",
"path": "volume move start",
"query": "-vserver vs1|vs2|vs3 -destination-aggregate aggr1|aggr2"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
next |
self |
_links
self |
role_privilege
A tuple containing a REST endpoint or a command/command directory path and the access level assigned to that endpoint or command/command directory. If the "path" attribute refers to a command/command directory path, the tuple could additionally contain an optional query. The REST endpoint can be a resource-qualified endpoint. At present, the only supported resource-qualified endpoints are the following
Snapshots APIs
/api/storage/volumes/{volume.uuid}/snapshots
File System Analytics APIs
/api/storage/volumes/{volume.uuid}/files
/api/storage/volumes/{volume.uuid}/top-metrics/clients
/api/storage/volumes/{volume.uuid}/top-metrics/directories
/api/storage/volumes/{volume.uuid}/top-metrics/files
/api/storage/volumes/{volume.uuid}/top-metrics/users
/api/svm/svms/{svm.uuid}/top-metrics/clients
/api/svm/svms/{svm.uuid}/top-metrics/directories
/api/svm/svms/{svm.uuid}/top-metrics/files
/api/svm/svms/{svm.uuid}/top-metrics/users
/api/protocols/s3/services/{svm.uuid}/users
In the above APIs, wildcard character * could be used in place of {volume.uuid} or {svm.uuid} to denote all volumes or all SVMs, depending upon whether the REST endpoint references volumes or SVMs. The {volume.uuid} refers to the -instance-uuid field value in the "volume show" command output at diagnostic privilege level. It can also be fetched through REST endpoint /api/storage/volumes.
_links |
access |
string |
Access level for the REST endpoint or command/command directory path. If it denotes the access level for a command/command directory path, the only supported enum values are 'none','readonly' and 'all'. |
path |
string |
Either of REST URI/endpoint OR command/command directory path. |
query |
string |
Optional attribute that can be specified only if the "path" attribute refers to a command/command directory path. The privilege tuple implicitly defines a set of objects the role can or cannot access at the specified access level. The query further reduces this set of objects to a subset of objects that the role is allowed to access. The query attribute must be applicable to the command/command directory specified by the "path" attribute. It is defined using one or more parameters of the command/command directory path specified by the "path" attribute. |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
