REST API reference
Retrieve privilege details of the specified role
GET /security/roles/{owner.uuid}/{name}/privileges
Introduced In: 9.6
Retrieves privilege details of the specified role.
  • security login rest-role show
owner.uuid
string
path
True
Role owner UUID
name
string
path
True
Role name
fields
array[string]
query
False
Specify the fields to return.
max_records
integer
query
False
return_records
boolean
query
False
  • Default value: 1
return_timeout
integer
query
False
  • Default value: 15
  • Max value: 120
  • Min value: 0
order_by
array[string]
query
False
Status: 200, Ok
Name Type Description
_links
_links
num_records
integer
Number of records
records
array[role_privilege]
    "next": {
      "href": "/api/resourcelink"
  "records": [
      "access": "readonly",
      "path": "/api/storage/volumes"
Status: Default, Error
error
error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
next
self
self
role_privilege
A tuple containing the REST endpoint and the access level assigned to that endpoint.
_links
_links
access
string
Access level for the REST endpoint.
path
string
REST URI/endpoint
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
