Retrieve cluster SSH server ciphers, MAC algorithms, key exchange algorithms, and connection limits
GET /security/ssh
Introduced In: 9.7
Retrieves the cluster SSH server ciphers, MAC algorithms, key exchange algorithms, and connection limits.
Related ONTAP commands
security ssh -
security protocol ssh
Status: 200, Ok
| Name | Type | Description |
_links  |
ciphers  |
array[string]  |
Ciphers for encrypting the data.  |
connections_per_second  |
integer  |
Maximum connections allowed per second.  |
key_exchange_algorithms  |
array[string]  |
Key exchange algorithms.  |
mac_algorithms  |
array[string]  |
MAC algorithms.  |
max_authentication_retry_count  |
integer  |
Maximum authentication retries allowed before closing the connection.  |
max_instances  |
integer  |
Maximum possible simultaneous connections.  |
per_source_limit  |
integer  |
Maximum connections from the same client host.  |
      "href": "/api/resourcelink"
  "ciphers": [
    "aes256_ctr",
    "aes192_ctr",
    "aes128_ctr"
  "key_exchange_algorithms": [
    "diffie_hellman_group_exchange_sha256",
    "ecdh_sha2_nistp256"
  "mac_algorithms": [
    "hmac_sha2_512",
    "hmac_sha2_512_etm"
Status: Default, Error
error  |
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
href  |
string  |
_links
self  |
code  |
string  |
Argument code  |
message  |
string  |
Message argument  |
returned_error
arguments  |
array[error_arguments]  |
Message arguments  |
code  |
string  |
Error code  |
message  |
string  |
Error message  |
target  |
string  |
The target parameter that caused the error.  |
