REST API reference
Retrieve cluster SSH server ciphers, MAC algorithms, key exchange algorithms, and connection limits
GET /security/ssh
Introduced In: 9.7
Retrieves the cluster SSH server ciphers, MAC algorithms, key exchange algorithms, host key algorithms, connection limits, login grace time, and ssh-rsa enabled status for public key algorithms.
  • security ssh
  • security protocol ssh
Status: 200, Ok
Name Type Description
_links
_links
ciphers
array[string]
Ciphers for encrypting the data.
connections_per_second
integer
Maximum connections allowed per second.
host_key_algorithms
array[string]
Host key algorithms. The host key algorithms 'ssh_ed25519' and 'ssh_rsa' can be configured only in non-FIPS mode.
is_rsa_in_publickey_algorithms_enabled
boolean
Enables or disables the ssh-rsa signature scheme, which uses the SHA-1 hash algorithm, for RSA keys in public key algorithms. If this flag is false, older SSH implementations might fail to authenticate using RSA keys. This flag should be enabled only as a temporary measure until legacy SSH client implementations can be upgraded or reconfigured with another key type, for example: ECDSA.
key_exchange_algorithms
array[string]
Key exchange algorithms.
login_grace_time
integer
The SSH connection login grace time allowed for the connection.
mac_algorithms
array[string]
MAC algorithms.
max_authentication_retry_count
integer
Maximum authentication retries allowed before closing the connection.
max_instances
integer
Maximum possible simultaneous connections.
per_source_limit
integer
Maximum connections from the same client host.
      "href": "/api/resourcelink"
  "ciphers": [
    "aes256_ctr",
    "aes192_ctr",
    "aes128_ctr"
  "host_key_algorithms": [
    "ecdsa_sha2_nistp256",
    "ssh_rsa",
    "rsa_sha2_256",
    "rsa_sha2_512"
  "key_exchange_algorithms": [
    "diffie_hellman_group_exchange_sha256",
    "ecdh_sha2_nistp256",
    "diffie_hellman_group18_sha512"
  "mac_algorithms": [
    "hmac_sha2_512",
    "hmac_sha2_512_etm"
Status: Default, Error
error
returned_error
Example error
  "error": {
    "arguments": [
        "code": "string",
        "message": "string"
    "code": "4",
    "target": "uuid"
string
self
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
