Retrieve cluster SSH server ciphers, MAC algorithms, key exchange algorithms, and connection limits
Accesses the cluster's SSH server configuration details, including ciphers, MAC algorithms, key exchange algorithms, host key algorithms, and connection limits. Use this information to review or update security settings for SSH connections.
HTTP method and endpoint
GET /security/ssh
Introduced in
ONTAP 9.7
Usage notes
Retrieves the cluster SSH server ciphers, MAC algorithms, key exchange algorithms, host key algorithms, connection limits, and ssh-rsa enabled status for public key algorithms.
Related ONTAP commands
security ssh -
security protocol ssh
Status: 200, Ok
| Name | Type | Description |
_links |
ciphers |
array[string] |
Ciphers for encrypting the data. |
connections_per_second |
integer |
Maximum connections allowed per second. |
host_key_algorithms |
array[string] |
Host key algorithms. The host key algorithm 'ssh_ed25519' can be configured only in non-FIPS mode. |
is_rsa_in_publickey_algorithms_enabled |
boolean |
Enables or disables the ssh-rsa signature scheme, which uses the SHA-1 hash algorithm, for RSA keys in public key algorithms. If this flag is false, older SSH implementations might fail to authenticate using RSA keys. This flag should be enabled only as a temporary measure until legacy SSH client implementations can be upgraded or reconfigured with another key type, for example: ECDSA. |
key_exchange_algorithms |
array[string] |
Key exchange algorithms. |
mac_algorithms |
array[string] |
MAC algorithms. |
max_authentication_retry_count |
integer |
Maximum authentication retries allowed before closing the connection. |
max_instances |
integer |
Maximum possible simultaneous connections. |
per_source_limit |
integer |
Maximum connections from the same client host. |
"href": "/api/resourcelink"
"ciphers": [
"aes256_ctr",
"aes192_ctr",
"aes128_ctr"
"host_key_algorithms": [
"ecdsa_sha2_nistp256",
"ssh_rsa"
"key_exchange_algorithms": [
"diffie_hellman_group_exchange_sha256",
"ecdh_sha2_nistp256",
"diffie_hellman_group18_sha512"
"mac_algorithms": [
"hmac_sha2_512",
"hmac_sha2_512_etm"
Status: Default, Error
error |
Example error
"error": {
"arguments": [
"code": "string",
"message": "string"
"code": "4",
"target": "uuid"
href |
string |
_links
self |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
