Update a cloud target
PATCH /cloud/targets/{uuid}
Introduced In: 9.6
Updates the cloud target specified by the UUID with the fields in the body. This request starts a job and returns a link to that job.
Related ONTAP commands
storage aggregate object-store config modify
uuid |
string |
path |
True |
Cloud target UUID |
ignore_warnings |
boolean |
query |
False |
Specifies whether or not warnings should be ignored. |
check_only |
boolean |
query |
False |
Do not modify the configuration, only check that the PATCH request succeeds. |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
access_key |
string |
Access key ID for AWS_S3 and other S3 compatible provider types. |
authentication_type |
string |
Authentication used to access the target. SnapMirror does not yet support CAP. Required in POST. |
azure_account |
string |
Azure account |
azure_private_key |
string |
Azure access key |
azure_sas_token |
string |
Shared access signature token to access Azure containers and blobs. |
cap_url |
string |
This parameter is available only when auth-type is CAP. It specifies a full URL of the request to a CAP server for retrieving temporary credentials (access-key, secret-pasword, and session token) for accessing the object store. |
certificate_validation_enabled |
boolean |
Is SSL/TLS certificate validation enabled? The default value is true. This can only be modified for SGWS, IBM_COS, and ONTAP_S3 provider types.
cluster |
name |
string |
Cloud target name |
port |
integer |
Port number of the object store that ONTAP uses when establishing a connection. Required in POST.
read_latency_warning_threshold |
integer |
The warning threshold for read latency that is used to determine when an alert ems for a read operation from an object store should be issued. |
scope |
string |
If the cloud target is owned by a data SVM, then the scope is set to svm. Otherwise it will be set to cluster. |
secret_password |
string |
Secret access key for AWS_S3 and other S3 compatible provider types. |
server |
string |
Fully qualified domain name of the object store server. Required on POST. For Amazon S3, server name must be an AWS regional endpoint in the format s3.amazonaws.com or s3- |
server_side_encryption |
string |
Encryption of data at rest by the object store server for AWS_S3 and other S3 compatible provider types. In most cases it is best not to change default value of "sse_s3" for object store servers which support SSE-S3 encryption. The encryption is in addition to any encryption done by ONTAP at a volume or at an aggregate level. Note that changing this option does not change encryption of data which already exist in the object store.
snapmirror_use |
string |
Use of the cloud target by SnapMirror. |
ssl_enabled |
boolean |
SSL/HTTPS enabled or not |
svm |
This field is only applicable when used for SnapMirror and FabricLink. For POST and PATCH, SVM information is required for SnapMirror and FabricLink targets and not allowed for FabricPool targets. |
url_style |
string |
URL style used to access S3 bucket. |
use_http_proxy |
boolean |
Use HTTP proxy when connecting to the object store. |
used |
integer |
The amount of cloud space used by all the aggregates attached to the target, in bytes. This field is only populated for FabricPool targets. The value is recalculated once every 5 minutes. |
uuid |
string |
Cloud target UUID |
Example request
"access_key": "string",
"authentication_type": "string",
"azure_account": "string",
"azure_private_key": "string",
"azure_sas_token": "string",
"cap_url": "https://123.45.67.89:1234/CAP/api/v1/credentials?agency=myagency&mission=mymission&role=myrole",
"name": "string",
"scope": "string",
"secret_password": "string",
"server": "string",
"server_side_encryption": "string",
"snapmirror_use": "string",
"svm": {
"name": "svm1",
"url_style": "string",
"used": 0,
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
786436 |
VLDB is not running. |
786908 |
Capability check failed. |
787016 |
An object store configuration with the same combination of server and container name already exists. |
787036 |
Server name is invalid. A valid server name must be a fully qualified domain name. |
787038 |
Object store provider type requires a FabricPool license. |
787039 |
Failed to retrieve FabricPool capacity license information. |
787054 |
An object store configuration with the same combination of server, azure account and container name already exists. |
787064 |
Object store server provider type does not match object store provider type. Use the provider type that matches the server. |
787065 |
Certificate validation must be enabled for the object store provider. |
787066 |
Certificate validation cannot be specified when the "-is-ssl-enabled" parameter is false. |
787068 |
Disabling certificate validation requires an effective cluster version of ONTAP 9.4.0 or later. |
787089 |
The object store provider supports the virtual hosted-style, and the specified "-server" contains the container name. The container specified in the "-server" parameter must be the same as the name of the container specified in the "-container" parameter. |
787133 |
Could not retrieve temporary credentials from the CAP server. |
787134 |
Could not retrieve temporary credentials from the CAP server due to an unexpected response. |
787136 |
Specifying "CAP" as the "-auth-type" requires an effective cluster version of ONTAP 9.5.0 or later. |
787148 |
The clock on the node is behind by more than the maximum of 5 minutes. |
787149 |
The clock on the node is ahead by more than the maximum of 5 minutes. |
787184 |
Using HTTP proxies with FabricPool requires an effective cluster version of ONTAP 9.7.0 or later. |
787185 |
There is no HTTP proxy for IPspace. Refer to the "vserver http-proxy" man page for details. |
787188 |
Object store configuration belongs to cluster and cannot be modified from the local cluster, unless the cluster is in switchover mode. |
787209 |
Object store is not accessible from the partner cluster in a MetroCluster configuration. |
787216 |
Cannot perform object store configuration operations on a cluster that is waiting for switchback. |
787223 |
Specifying "GCP_SA" as the "-auth-type" requires an effective cluster version of ONTAP 9.7.0 or later. |
787227 |
Specifying "Azure_MSI" as the "-auth-type" requires an effective cluster version of ONTAP 9.7 or later. |
787228 |
SSL is required for this configuration. |
787229 |
Cannot perform operation as URL style is not supported with object store provider type. |
787233 |
The hash key for enabling this FabricPool feature is not present on the cluster. |
787234 |
The hash key provided for the node to enable this FabricPool feature is not valid. |
787254 |
The parameter is not supported on this system. |
787257 |
The parameter "-encryption-context" is only applicable for AWS object store provider. |
787301 |
ONTAP S3 Bucket is of type NAS and is not supported as a target for FabricPool. |
787302 |
Cannot use HTTP port with "-is-ssl-enabled" set to true. |
787303 |
Cannot use HTTPS port with "-is-ssl-enabled" set to false. |
787306 |
45940761 |
Hostname cannot be resolved. Check the spelling of the hostname and check the system DNS availability using the "vserver services name-service dns check" command. |
45940778 |
Bucket already exists. |
href |
string |
_links
cluster
ipspace
IPspace to use in order to reach the cloud target.
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
name |
string |
uuid |
string |
cloud_target
access_key |
string |
string |
azure_account |
string |
Azure account |
azure_private_key |
string |
Azure access key |
azure_sas_token |
string |
cap_url |
string |
boolean |
cluster |
name |
string |
Cloud target name |
port |
integer |
integer |
scope |
string |
secret_password |
string |
server |
string |
string |
snapmirror_use |
string |
ssl_enabled |
boolean |
svm |
url_style |
string |
use_http_proxy |
boolean |
used |
integer |
uuid |
string |
Cloud target UUID |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
