Update a cloud target
Updates a cloud target by specifying the desired fields, initiating a job to apply the changes. Use this endpoint when you need to modify configurations or properties of a cloud target in your storage setup.
HTTP method and endpoint
PATCH /cloud/targets/{uuid}
Introduced in
ONTAP 9.6
Usage notes
Updates the cloud target specified by the UUID with the fields in the body. This request starts a job and returns a link to that job.
Related ONTAP commands
storage aggregate object-store config modify
uuid |
string |
path |
True |
Cloud target UUID |
ignore_warnings |
boolean |
query |
False |
Specifies whether or not warnings should be ignored. |
check_only |
boolean |
query |
False |
Do not modify the configuration, only check that the PATCH request succeeds. |
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
access_key |
string |
Access key ID for AWS_S3 and other S3 compatible provider types. |
authentication_type |
string |
Authentication used to access the target. SnapMirror does not yet support CAP. Required in POST. |
azure_account |
string |
Azure account |
azure_msi_token |
string |
Managed Service Identity (MSI) token required to authenticate to the Azure object store. This form of authentication is only supported on Azure NetApp Files. |
azure_private_key |
string |
Azure access key |
azure_sas_token |
string |
Shared access signature token to access Azure containers and blobs. |
cap_url |
string |
This parameter is available only when auth-type is CAP. It specifies a full URL of the request to a CAP server for retrieving temporary credentials (access-key, secret-password, and session token) for accessing the object store. |
certificate_validation_enabled |
boolean |
Is SSL/TLS certificate validation enabled? The default value is true. This can only be modified for SGWS, IBM_COS, and ONTAP_S3 provider types.
cluster |
name |
string |
Cloud target name |
port |
integer |
Port number of the object store that ONTAP uses when establishing a connection. Required in POST.
read_latency_warning_threshold |
integer |
The warning threshold for read latency that is used to determine when an alert ems for a read operation from an object store should be issued. |
scope |
string |
If the cloud target is owned by a data SVM, then the scope is set to svm. Otherwise it will be set to cluster. |
secret_password |
string |
Secret access key for AWS_S3 and other S3 compatible provider types. |
server |
string |
Fully qualified domain name of the object store server. Required on POST. For Amazon S3, server name must be an AWS regional endpoint in the format s3.amazonaws.com or s3- |
server_side_encryption |
string |
Encryption of data at rest by the object store server for AWS_S3 and other S3 compatible provider types. In most cases it is best not to change default value of "sse_s3" for object store servers which support SSE-S3 encryption. The encryption is in addition to any encryption done by ONTAP at a volume or at an aggregate level. Note that changing this option does not change encryption of data which already exist in the object store.
snapmirror_use |
string |
Use of the cloud target by SnapMirror. |
ssl_enabled |
boolean |
SSL/HTTPS enabled or not |
svm |
This field is only applicable when used for SnapMirror and FabricLink. For POST and PATCH, SVM information is required for SnapMirror and FabricLink targets when the scope is svm and is not allowed for FabricPool targets. For GET, this field is not set if the scope of the cloud target is "cluster". |
url_style |
string |
URL style used to access S3 bucket. |
use_http_proxy |
boolean |
Use HTTP proxy when connecting to the object store. |
used |
integer |
The amount of cloud space used by all the aggregates attached to the target, in bytes. This field is only populated for FabricPool targets. The value is recalculated once every 5 minutes. |
uuid |
string |
Cloud target UUID |
Example request
"access_key": "string",
"authentication_type": "string",
"azure_account": "string",
"azure_msi_token": "string",
"azure_private_key": "string",
"azure_sas_token": "string",
"cap_url": "https://123.45.67.89:1234/CAP/api/v1/credentials?agency=myagency&mission=mymission&role=myrole",
"name": "string",
"scope": "string",
"secret_password": "string",
"server": "string",
"server_side_encryption": "string",
"snapmirror_use": "string",
"svm": {
"name": "svm1",
"url_style": "string",
"used": 0,
"uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
786436 |
VLDB is not running. |
786908 |
Capability check failed. |
787016 |
An object store configuration with the same combination of server and container name already exists. |
787036 |
Server name is invalid. A valid server name must be a fully qualified domain name. |
787038 |
Object store provider type requires a FabricPool license. |
787039 |
Failed to retrieve FabricPool capacity license information. |
787054 |
An object store configuration with the same combination of server, azure account and container name already exists. |
787064 |
Object store server provider type does not match object store provider type. Use the provider type that matches the server. |
787065 |
Certificate validation must be enabled for the object store provider. |
787066 |
Certificate validation cannot be specified when the "-is-ssl-enabled" parameter is false. |
787068 |
Disabling certificate validation requires an effective cluster version of ONTAP 9.4.0 or later. |
787089 |
The object store provider supports the virtual hosted-style, and the specified "-server" contains the container name. The container specified in the "-server" parameter must be the same as the name of the container specified in the "-container" parameter. |
787133 |
Could not retrieve temporary credentials from the CAP server. |
787134 |
Could not retrieve temporary credentials from the CAP server due to an unexpected response. |
787136 |
Specifying "CAP" as the "-auth-type" requires an effective cluster version of ONTAP 9.5.0 or later. |
787148 |
The clock on the node is behind by more than the maximum of 5 minutes. |
787149 |
The clock on the node is ahead by more than the maximum of 5 minutes. |
787184 |
Using HTTP proxies with FabricPool requires an effective cluster version of ONTAP 9.7.0 or later. |
787185 |
There is no HTTP proxy for IPspace. Refer to the "vserver http-proxy" man page for details. |
787188 |
Object store configuration belongs to cluster and cannot be modified from the local cluster, unless the cluster is in switchover mode. |
787209 |
Object store is not accessible from the partner cluster in a MetroCluster configuration. |
787216 |
Cannot perform object store configuration operations on a cluster that is waiting for switchback. |
787223 |
Specifying "GCP_SA" as the "-auth-type" requires an effective cluster version of ONTAP 9.7.0 or later. |
787227 |
Specifying "Azure_MSI" as the "-auth-type" requires an effective cluster version of ONTAP 9.7 or later. |
787228 |
SSL is required for this configuration. |
787229 |
Cannot perform operation as URL style is not supported with object store provider type. |
787233 |
The hash key for enabling this FabricPool feature is not present on the cluster. |
787234 |
The hash key provided for the node to enable this FabricPool feature is not valid. |
787254 |
The parameter is not supported on this system. |
787257 |
The parameter "-encryption-context" is only applicable for AWS object store provider. |
787301 |
ONTAP S3 Bucket is of type NAS and is not supported as a target for FabricPool. |
787302 |
Cannot use HTTP port with "-is-ssl-enabled" set to true. |
787303 |
Cannot use HTTPS port with "-is-ssl-enabled" set to false. |
787306 |
787350 |
Modifying an object store configuration with a Managed Service Identity (MSI) token is only supported on Azure NetApp Files. |
787351 |
Internal Error. Invalid authentication type. |
787352 |
Modifying an object store configuration with a Managed Service Identity (MSI) token requires an effective cluster version of ONTAP 9.16.1 or later. |
787353 |
Modifying an object store configuration with a Managed Service Identity (MSI) token is not supported for this owner. |
787354 |
The specified properties are mutually exclusive. |
787355 |
azure_msi |
45940761 |
Hostname cannot be resolved. Check the spelling of the hostname and check the system DNS availability using the "vserver services name-service dns check" command. |
45940778 |
Bucket already exists. |
href |
string |
_links
cluster
ipspace
IPspace to use in order to reach the cloud target.
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
svm
name |
string |
uuid |
string |
cloud_target
access_key |
string |
string |
azure_account |
string |
Azure account |
azure_msi_token |
string |
azure_private_key |
string |
Azure access key |
azure_sas_token |
string |
cap_url |
string |
boolean |
cluster |
name |
string |
Cloud target name |
port |
integer |
integer |
scope |
string |
secret_password |
string |
server |
string |
string |
snapmirror_use |
string |
ssl_enabled |
boolean |
svm |
url_style |
string |
use_http_proxy |
boolean |
used |
integer |
uuid |
string |
Cloud target UUID |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
