REST API reference
Update a cloud target
PATCH /cloud/targets/{uuid}
Introduced In: 9.6
Updates the cloud target specified by the UUID with the fields in the body. This request starts a job and returns a link to that job.
  • storage aggregate object-store config modify
uuid
string
path
True
Cloud target UUID
ignore_warnings
boolean
query
False
Specifies whether or not warnings should be ignored.
check_only
boolean
query
False
Do not modify the configuration, only check that the PATCH request succeeds.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
access_key
string
Access key ID for AWS_S3 and other S3 compatible provider types.
authentication_type
string
Authentication used to access the target. SnapMirror does not yet support CAP. Required in POST.
azure_account
string
Azure account
azure_msi_token
string
Managed Service Identity (MSI) token required to authenticate to the Azure object store. This form of authentication is only supported on Azure NetApp Files.
azure_private_key
string
Azure access key
azure_sas_token
string
Shared access signature token to access Azure containers and blobs.
cap_url
string
This parameter is available only when auth-type is CAP. It specifies a full URL of the request to a CAP server for retrieving temporary credentials (access-key, secret-password, and session token) for accessing the object store.
certificate_validation_enabled
boolean
Is SSL/TLS certificate validation enabled? The default value is true. This can only be modified for SGWS, IBM_COS, and ONTAP_S3 provider types.
  • Introduced in: 9.6
  • x-nullable: true
cluster
cluster
name
string
Cloud target name
port
integer
Port number of the object store that ONTAP uses when establishing a connection. Required in POST.
  • x-nullable: true
read_latency_warning_threshold
integer
The warning threshold for read latency that is used to determine when an alert ems for a read operation from an object store should be issued.
scope
string
If the cloud target is owned by a data SVM, then the scope is set to svm. Otherwise it will be set to cluster.
secret_password
string
Secret access key for AWS_S3 and other S3 compatible provider types.
server
string
Fully qualified domain name of the object store server. Required on POST. For Amazon S3, server name must be an AWS regional endpoint in the format s3.amazonaws.com or s3-.amazonaws.com, for example, s3-us-west-2.amazonaws.com. The region of the server and the bucket must match. For Azure, if the server is a "blob.core.windows.net" or a "blob.core.usgovcloudapi.net", then a value of azure-account followed by a period is added in front of the server.
server_side_encryption
string
Encryption of data at rest by the object store server for AWS_S3 and other S3 compatible provider types. In most cases it is best not to change default value of "sse_s3" for object store servers which support SSE-S3 encryption. The encryption is in addition to any encryption done by ONTAP at a volume or at an aggregate level. Note that changing this option does not change encryption of data which already exist in the object store.
  • enum: ["none", "sse_s3", "sse_kms", "dsse_kms"]
  • Introduced in: 9.7
  • x-nullable: true
snapmirror_use
string
Use of the cloud target by SnapMirror.
ssl_enabled
boolean
SSL/HTTPS enabled or not
svm
svm
This field is only applicable when used for SnapMirror and FabricLink. For POST and PATCH, SVM information is required for SnapMirror and FabricLink targets when the scope is svm and is not allowed for FabricPool targets. For GET, this field is not set if the scope of the cloud target is "cluster".
url_style
string
URL style used to access S3 bucket.
use_http_proxy
boolean
Use HTTP proxy when connecting to the object store.
used
integer
The amount of cloud space used by all the aggregates attached to the target, in bytes. This field is only populated for FabricPool targets. The value is recalculated once every 5 minutes.
uuid
string
Cloud target UUID
Example request
  "access_key": "string",
  "authentication_type": "string",
  "azure_account": "string",
  "azure_msi_token": "string",
  "azure_private_key": "string",
  "azure_sas_token": "string",
  "cap_url": "https://123.45.67.89:1234/CAP/api/v1/credentials?agency=myagency&mission=mymission&role=myrole",
  "name": "string",
  "scope": "string",
  "secret_password": "string",
  "server": "string",
  "server_side_encryption": "string",
  "snapmirror_use": "string",
  "svm": {
    "name": "svm1",
  "url_style": "string",
  "used": 0,
  "uuid": "string"
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
786436
VLDB is not running.
786908
Capability check failed.
787016
An object store configuration with the same combination of server and container name already exists.
787036
Server name is invalid. A valid server name must be a fully qualified domain name.
787038
Object store provider type requires a FabricPool license.
787039
Failed to retrieve FabricPool capacity license information.
787054
An object store configuration with the same combination of server, azure account and container name already exists.
787064
Object store server provider type does not match object store provider type. Use the provider type that matches the server.
787065
Certificate validation must be enabled for the object store provider.
787066
Certificate validation cannot be specified when the "-is-ssl-enabled" parameter is false.
787068
Disabling certificate validation requires an effective cluster version of ONTAP 9.4.0 or later.
787089
The object store provider supports the virtual hosted-style, and the specified "-server" contains the container name. The container specified in the "-server" parameter must be the same as the name of the container specified in the "-container" parameter.
787133
Could not retrieve temporary credentials from the CAP server.
787134
Could not retrieve temporary credentials from the CAP server due to an unexpected response.
787136
Specifying "CAP" as the "-auth-type" requires an effective cluster version of ONTAP 9.5.0 or later.
787148
The clock on the node is behind by more than the maximum of 5 minutes.
787149
The clock on the node is ahead by more than the maximum of 5 minutes.
787184
Using HTTP proxies with FabricPool requires an effective cluster version of ONTAP 9.7.0 or later.
787185
There is no HTTP proxy for IPspace. Refer to the "vserver http-proxy" man page for details.
787188
Object store configuration belongs to cluster and cannot be modified from the local cluster, unless the cluster is in switchover mode.
787209
Object store is not accessible from the partner cluster in a MetroCluster configuration.
787216
Cannot perform object store configuration operations on a cluster that is waiting for switchback.
787223
Specifying "GCP_SA" as the "-auth-type" requires an effective cluster version of ONTAP 9.7.0 or later.
787227
Specifying "Azure_MSI" as the "-auth-type" requires an effective cluster version of ONTAP 9.7 or later.
787228
SSL is required for this configuration.
787229
Cannot perform operation as URL style is not supported with object store provider type.
787233
The hash key for enabling this FabricPool feature is not present on the cluster.
787234
The hash key provided for the node to enable this FabricPool feature is not valid.
787254
The parameter is not supported on this system.
787257
The parameter "-encryption-context" is only applicable for AWS object store provider.
787301
ONTAP S3 Bucket is of type NAS and is not supported as a target for FabricPool.
787302
Cannot use HTTP port with "-is-ssl-enabled" set to true.
787303
Cannot use HTTPS port with "-is-ssl-enabled" set to false.
787306
787325
FabricPool is not supported on this platform.
787350
Modifying an object store configuration with a Managed Service Identity (MSI) token is only supported on Azure NetApp Files.
787351
Internal Error. Invalid authentication type.
787352
Modifying an object store configuration with a Managed Service Identity (MSI) token requires an effective cluster version of ONTAP 9.16.1 or later.
787353
Modifying an object store configuration with a Managed Service Identity (MSI) token is not supported for this owner.
787354
The specified properties are mutually exclusive.
787355
azure_msi authentication-type is only supported with Azure_Cloud provider-type.
787394
Modifying the "-new-object-store-name\" or "-server\" without providing a Managed Identity (MI) token is not supported for this configuration.
45940761
Hostname cannot be resolved. Check the spelling of the hostname and check the system DNS availability using the "vserver services name-service dns check" command.
45940778
Bucket already exists.
string
cluster
ipspace
IPspace to use in order to reach the cloud target.
name
string
IPspace name
uuid
string
IPspace UUID
svm
name
string
uuid
string
cloud_target
access_key
string
authentication_type
string
azure_account
string
Azure account
azure_msi_token
string
azure_private_key
string
Azure access key
azure_sas_token
string
cap_url
string
boolean
  • x-nullable: true
cluster
cluster
name
string
Cloud target name
port
integer
  • x-nullable: true
integer
scope
string
secret_password
string
server
string
string
  • x-nullable: true
snapmirror_use
string
ssl_enabled
boolean
svm
svm
url_style
string
use_http_proxy
boolean
used
integer
uuid
string
Cloud target UUID
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
