REST API reference
Update an S3 policy configuration
Updates the S3 policy configuration of a storage virtual machine (SVM) to reflect changes in policy statements or comments. Use this endpoint when you need to modify the existing policy attributes for S3 services.
HTTP method and endpoint
PATCH /protocols/s3/services/{svm.uuid}/policies/{name}
Introduced in
ONTAP 9.8
Usage notes
Updates the S3 policy configuration of an SVM.
Important notes
  • The following fields can be modified for a policy:
    • comment - Any information related to the policy.
    • statements - Specifies the array of policy statements.
  • vserver object-store-server policy modify
  • vserver object-store-server policy modify-statement
name
string
path
True
Policy name
svm.uuid
string
path
True
Request Body
Name Type Description
comment
string
Can contain any additional information about the S3 policy.
read-only
boolean
Specifies whether or not the s3 policy is read only. This parameter should not be specified in the POST method.
statements
array[s3_policy_statement]
Specifies the policy statements.
svm
svm
Example request
  "comment": "S3 policy.",
  "statements": [
      "actions": [
      "effect": "allow",
      "index": 0,
      "resources": [
        "bucket1",
        "bucket1/*"
      "sid": "FullAccessToBucket1"
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
92405906
The specified action name is invalid.
92405963
Failed to create s3 policy statements "{policy name}". Reason: "{reason of failure}". Resolve all issues and retry the operation.
92405953
Object store server read-only policies do not support create, modify, delete, add-statement, delete-statement and modify-statement operations.
92406075
Failed to modify policy statement for policy "{policy name}". Reason: "{reason of failure}". Valid ways to specify a resource are "__", "", "/.../...".". //end row
|Name |Type |Description
|actions |array[string] a|For each resource, S3 supports a set of operations. The resource operations allowed or denied are identified by an action list:
  • GetObject - retrieves objects from a bucket.
  • PutObject - puts objects in a bucket.
  • DeleteObject - deletes objects from a bucket.
  • ListBucket - lists the objects in a bucket.
  • GetBucketAcl - retrieves the access control list (ACL) of a bucket.
  • GetObjectAcl - retrieves the access control list (ACL) of an object.
  • ListAllMyBuckets - lists all of the buckets in a server.
  • ListBucketMultipartUploads - lists the multipart uploads in progress for a bucket.
  • ListMultipartUploadParts - lists the parts in a multipart upload.
  • CreateBucket - creates a new bucket.
  • DeleteBucket - deletes an existing bucket.
  • GetObjectTagging - retrieves the tag set of an object.
  • PutObjecttagging - sets the tag set for an object.
  • DeleteObjectTagging - deletes the tag set of an object.
  • GetBucketLocation - retrieves the location of a bucket.
  • GetBucketVersioning - retrieves the versioning configuration of a bucket.
  • PutBucketVersioning - modifies the versioning configuration of a bucket.
  • ListBucketVersions - lists the object versions in a bucket.
  • PutBucketPolicy - puts bucket policy on the bucket specified.
  • GetBucketPolicy - retrieves the bucket policy of a bucket.
  • DeleteBucketPolicy - deletes the policy created for a bucket. The wildcard character "*" can be used to form a regular expression for specifying actions.
|effect |string a|Specifies whether access is allowed or denied. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access.
|index |integer a|Specifies a unique statement index used to identify a particular statement. This parameter should not be specified in the POST method. A statement index is automatically generated. It is not retrieved in the GET method.
|resources |array[string] a|
|sid |string a|Specifies the statement identifier which contains additional information about the statement.
[#href] [.api-collapsible-fifth-title] href
[cols=3*,options=header]
|href |string a|
[#_links] [.api-collapsible-fifth-title] _links [#svm] [.api-collapsible-fifth-title] svm
|name |string a|The name of the SVM. This field cannot be specified in a PATCH method.
|uuid |string a|The unique identifier of the SVM. This field cannot be specified in a PATCH method.
[#s3_policy] [.api-collapsible-fifth-title] s3_policy
An S3 policy is an object. It defines resource (bucket, folder or object) permissions. These policies get evaluated when an object store user user makes a request. Permissions in the policies determine whether the request is allowed or denied.
|comment |string a|Can contain any additional information about the S3 policy.
|read-only |boolean a|Specifies whether or not the s3 policy is read only. This parameter should not be specified in the POST method.
|statements |array[s3_policy_statement] a|Specifies the policy statements.
|svm |svm a|SVM, applies only to SVM-scoped objects.
[#error_arguments] [.api-collapsible-fifth-title] error_arguments
|code |string a|Argument code
|message |string a|Message argument
[#returned_error] [.api-collapsible-fifth-title] returned_error
|arguments |array[error_arguments] a|Message arguments
|code |string a|Error code
|message |string a|Error message
|target |string a|The target parameter that caused the error.
