REST API reference
Update an S3 policy configuration
Updates the S3 policy configuration of a Storage Virtual Machine (SVM) to adjust policy settings and statements according to your requirements. This endpoint is useful for managing access and permissions for object storage resources.
HTTP method and endpoint
PATCH /protocols/s3/services/{svm.uuid}/policies/{name}
Introduced in
ONTAP 9.8
Usage notes
Updates the S3 policy configuration of an SVM.
Important notes
  • The following fields can be modified for a policy:
    • comment - Any information related to the policy.
    • statements - Specifies the array of policy statements.
  • vserver object-store-server policy modify
  • vserver object-store-server policy modify-statement
name
string
path
True
Policy name
svm.uuid
string
path
True
Request Body
Name Type Description
comment
string
Can contain any additional information about the S3 policy.
read-only
boolean
Specifies whether or not the s3 policy is read only. This parameter should not be specified in the POST method.
statements
array[s3_policy_statement]
Specifies the policy statements.
svm
svm
Example request
  "comment": "S3 policy.",
  "statements": [
      "actions": [
      "effect": "allow",
      "index": 0,
      "resources": [
        "bucket1",
        "bucket1/*"
      "sid": "FullAccessToBucket1"
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
92405906
The specified action name is invalid.
92405963
Failed to create policy statements for policy. Reason: "{reason of failure}". Resolve all issues and retry the operation.
92405954
Object store server read-only policies do not support create, modify, delete, add-statement, delete-statement and modify-statement operations.
s3_policy_statement
Specifies information about a single access policy statement.
actions
array[string]
For each resource, S3 supports a set of operations. The resource operations allowed or denied are identified by an action list:
  • GetObject - retrieves objects from a bucket.
  • PutObject - puts objects in a bucket.
  • DeleteObject - deletes objects from a bucket.
  • ListBucket - lists the objects in a bucket.
  • GetBucketAcl - retrieves the access control list (ACL) of a bucket.
  • GetObjectAcl - retrieves the access control list (ACL) of an object.
  • ListAllMyBuckets - lists all of the buckets in a server.
  • ListBucketMultipartUploads - lists the multipart uploads in progress for a bucket.
  • ListMultipartUploadParts - lists the parts in a multipart upload.
  • GetObjectTagging - retrieves the tag set of an object.
  • PutObjecttagging - sets the tag set for an object.
  • DeleteObjectTagging - deletes the tag set of an object.
  • GetBucketLocation - retrieves the location of a bucket. The wildcard character "*" can be used to form a regular expression for specifying actions.
effect
string
Specifies whether access is allowed or denied. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access.
index
integer
Specifies a unique statement index used to identify a particular statement. This parameter should not be specified in the POST method. A statement index is automatically generated and is retrieved using the GET method.
resources
array[string]
sid
string
Specifies the statement identifier which contains additional information about the statement.
string
svm
name
string
The name of the SVM.
uuid
string
s3_policy
An S3 policy is an object. It defines resource (bucket, folder or object) permissions. These policies get evaluated when an object store user user makes a request. Permissions in the policies determine whether the request is allowed or denied.
comment
string
read-only
boolean
statements
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
