REST API reference
Update an S3 policy configuration
Updates the S3 policy configuration for a storage virtual machine (SVM) to modify details like comments or policy statements as needed.
HTTP method and endpoint
PATCH /protocols/s3/services/{svm.uuid}/policies/{name}
Introduced in
ONTAP 9.8
Usage notes
Updates the S3 policy configuration of an SVM.
Important notes
  • The following fields can be modified for a policy:
    • comment - Any information related to the policy.
    • statements - Specifies the array of policy statements.
  • vserver object-store-server policy modify
  • vserver object-store-server policy modify-statement
name
string
path
True
Policy name
svm.uuid
string
path
True
Request Body
Name Type Description
comment
string
Can contain any additional information about the S3 policy.
read-only
boolean
Specifies whether or not the s3 policy is read only. This parameter should not be specified in the POST method.
statements
array[s3_policy_statement]
Specifies the policy statements.
svm
svm
Example request
  "comment": "S3 policy.",
  "statements": [
      "actions": [
      "effect": "allow",
      "index": 0,
      "resources": [
        "bucket1",
        "bucket1/*"
      "sid": "FullAccessToBucket1"
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
92405906
The specified action name is invalid.
92405963
Failed to create policy statements for policy. Reason: "{reason of failure}". Resolve all issues and retry the operation.
92405954
Object store server read-only policies do not support create, modify, delete, add-statement, delete-statement and modify-statement operations.
s3_policy_statement
Specifies information about a single access policy statement.
actions
array[string]
For each resource, S3 supports a set of operations. The resource operations allowed or denied are identified by an action list:
  • GetObject - retrieves objects from a bucket.
  • PutObject - puts objects in a bucket.
  • DeleteObject - deletes objects from a bucket.
  • ListBucket - lists the objects in a bucket.
  • GetBucketAcl - retrieves the access control list (ACL) of a bucket.
  • GetObjectAcl - retrieves the access control list (ACL) of an object.
  • ListAllMyBuckets - lists all of the buckets in a server.
  • ListBucketMultipartUploads - lists the multipart uploads in progress for a bucket.
  • ListMultipartUploadParts - lists the parts in a multipart upload.
  • GetObjectTagging - retrieves the tag set of an object.
  • PutObjecttagging - sets the tag set for an object.
  • DeleteObjectTagging - deletes the tag set of an object. The wildcard character "*" can be used to form a regular expression for specifying actions.
effect
string
Specifies whether access is allowed or denied. If access (to allow) is not granted explicitly to a resource, access is implicitly denied. Access can also be denied explicitly to a resource, in order to make sure that a user cannot access it, even if a different policy grants access.
index
integer
Specifies a unique statement index used to identify a particular statement. This parameter should not be specified in the POST method. A statement index is automatically generated and is retrieved using the GET method.
resources
array[string]
sid
string
Specifies the statement identifier which contains additional information about the statement.
string
svm
name
string
The name of the SVM.
uuid
string
s3_policy
An S3 policy is an object. It defines resource (bucket, folder or object) permissions. These policies get evaluated when an object store user user makes a request. Permissions in the policies determine whether the request is allowed or denied.
comment
string
read-only
boolean
statements
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
