Update an IPsec policy
Updates a specific IPsec policy to modify its configurations or settings. Use this endpoint when you need to change the parameters of an existing policy to meet new security requirements.
HTTP method and endpoint
PATCH /security/ipsec/policies/{uuid}
Introduced in
ONTAP 9.8
Related ONTAP commands
security ipsec policy modify
uuid |
string |
path |
True |
IPsec policy UUID |
Request Body
| Name | Type | Description |
certificate |
Certificate for the IPsec policy. |
enabled |
boolean |
Indicates whether or not the policy is enabled. |
local_endpoint |
Local endpoint for the IPsec policy. |
local_identity |
string |
Local Identity |
protocol |
string |
Lower layer protocol to be covered by the IPsec policy. |
remote_endpoint |
Remote endpoint for the IPsec policy. |
remote_identity |
string |
Remote Identity |
uuid |
string |
Unique identifier of the IPsec policy. |
Example request
"certificate": {
"name": "string",
"local_endpoint": {
"address": "10.10.10.7",
"netmask": "24",
"port": "23"
"local_identity": "string",
"protocol": "17",
"remote_endpoint": {
"netmask": "24",
"port": "23"
"remote_identity": "string",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
66257097 |
Internal error. Failed to update the IPsec policy. |
66257099 |
Only one protocol can be specified. |
66257100 |
Only one local port can be specified. |
66257101 |
Only one remote port can be specified. |
66257110 |
Failed to create a policy sequencing value. |
66257113 |
Only one local IP subnet can be specified. |
66257114 |
Only one remote IP subnet can be specified. |
66257115 |
Port ranges containing more than one port are not supported. |
66257120 |
The subnet selector must be a host address (An IPv4 address with a 32-bit netmask or an IPv6 address with a 128-bit netmask). |
66257125 |
The local_endpoint.address must be specified with local_endpoint.netmask. |
66257126 |
The remote_endpoint.address must be specified with remote_endpoint.netmask. |
66257127 |
The local subnet must be configured as a non-zero subnet. |
66257128 |
Invalid ANY wildcard subnet. |
66257129 |
A specific local or remote port number is required when the remote subnet is configured as an ANY wildcard subnet. |
66257131 |
ESP in UDPv6 Encapsulation is not supported. |
66257135 |
The specified certificate is not found on the SVM. |
66257136 |
A certificate is not needed for the PSK authentication method. |
66257138 |
Remote identity is required when using certificate verification. |
66257139 |
Certificate with the specified UUID was not found. |
66257140 |
Only certificates with a client or server type are supported. |
66257142 |
Failed to create IPsec policy because the specified SVM is being migrated. |
66257143 |
Invalid IPsec policy provided. The subnet must be non-empty. |
66257199 |
Not all of the nodes in the cluster are running a version that supports the IPsec feature. |
66257200 |
The shared key does not meet required ASCII-range characters length. |
66257201 |
Support for the feature available with effective cluster version or later. |
66257305 |
The certificate UUID does not match the provided certificate name. |
href |
string |
_links
certificate
name |
string |
Certificate name |
uuid |
string |
Certificate UUID |
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input.
name |
string |
IPspace name |
uuid |
string |
IPspace UUID |
local_endpoint
address |
string |
IPv4 or IPv6 address |
netmask |
string |
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length. |
port |
string |
Application port to be covered by the IPsec policy |
remote_endpoint
address |
string |
netmask |
string |
port |
string |
svm
name |
string |
uuid |
string |
ipsec_policy
IPsec policy object.
certificate |
enabled |
boolean |
local_endpoint |
local_identity |
string |
Local Identity |
protocol |
string |
remote_endpoint |
remote_identity |
string |
Remote Identity |
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
