REST API reference
Update an IPsec policy
Updates a specific IPsec policy to modify its settings according to your network security requirements.
HTTP method and endpoint
PATCH /security/ipsec/policies/{uuid}
Introduced in
ONTAP 9.8
  • security ipsec policy modify
uuid
string
path
True
IPsec policy UUID
Request Body
Name Type Description
enabled
boolean
Indicates whether or not the policy is enabled.
ipspace
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input.
local_endpoint
local_endpoint
Local endpoint for the IPsec policy.
local_identity
string
Local Identity
name
string
IPsec policy name.
protocol
string
Lower layer protocol to be covered by the IPsec policy.
remote_endpoint
remote_endpoint
Remote endpoint for the IPsec policy.
remote_identity
string
Remote Identity
svm
svm
uuid
string
Unique identifier of the IPsec policy.
Example request
  "ipspace": {
    "name": "exchange",
  "local_endpoint": {
    "address": "10.10.10.7",
    "netmask": "24",
    "port": "23"
  "local_identity": "string",
  "name": "string",
  "protocol": "17",
  "remote_endpoint": {
    "netmask": "24",
    "port": "23"
  "remote_identity": "string",
  "svm": {
    "name": "svm1",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
66257097
Internal error. Failed to update the IPsec policy.
66257099
Only one protocol can be specified.
66257100
Only one local port can be specified.
66257101
Only one remote port can be specified.
66257110
Failed to create a policy sequencing value.
66257113
Only one local IP subnet can be specified.
66257114
Only one remote IP subnet can be specified.
66257115
Port ranges containing more than one port are not supported.
66257116
IPsec policy with the specified UUID was not found.
66257120
The subnet selector must be a host address (An IPv4 address with a 32-bit netmask or an IPv6 address with a 128-bit netmask).
string
ipspace
name
string
IPspace name
uuid
string
IPspace UUID
local_endpoint
address
string
IPv4 or IPv6 address
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always netmask length.
port
string
Application port to be covered by the IPsec policy
remote_endpoint
address
string
netmask
string
port
string
svm
name
string
The name of the SVM.
uuid
string
ipsec_policy
IPsec policy object.
enabled
boolean
ipspace
ipspace
local_endpoint
local_endpoint
local_identity
string
Local Identity
name
string
IPsec policy name.
protocol
string
remote_endpoint
remote_endpoint
remote_identity
string
Remote Identity
svm
svm
uuid
string
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
