REST API reference
Update an IPsec policy
PATCH /security/ipsec/policies/{uuid}
Introduced In: 9.8
Updates a specific IPsec policy.
  • security ipsec policy modify
uuid
string
path
True
IPsec policy UUID
Request Body
Name Type Description
certificate
certificate
Certificate for the IPsec policy.
certificate_modify_keepsa
boolean
Indicates whether old security associations are kept upon certificate modification.
enabled
boolean
Indicates whether or not the policy is enabled.
local_endpoint
local_endpoint
Local endpoint for the IPsec policy.
local_identity
string
Local Identity
ppk
ppk
Post-quantum pre-shared key information.
protocol
string
Lower layer protocol to be covered by the IPsec policy.
remote_endpoint
remote_endpoint
Remote endpoint for the IPsec policy.
remote_identity
string
Remote Identity
uuid
string
Unique identifier of the IPsec policy.
Example request
  "certificate": {
    "name": "string",
  "local_endpoint": {
    "address": "10.10.10.7",
    "netmask": "24",
    "port": "23"
  "local_identity": "string",
  "ppk": {
    "identity": "string"
  "protocol": "17",
  "remote_endpoint": {
    "netmask": "24",
    "port": "23"
  "remote_identity": "string",
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
66257097
Internal error. Failed to update the IPsec policy.
66257099
Only one protocol can be specified.
66257100
Only one local port can be specified.
66257101
Only one remote port can be specified.
66257110
Failed to create a policy sequencing value.
66257113
Only one local IP subnet can be specified.
66257114
Only one remote IP subnet can be specified.
66257115
Port ranges containing more than one port are not supported.
66257120
The subnet selector must be a host address (An IPv4 address with a 32-bit netmask or an IPv6 address with a 128-bit netmask).
66257125
The local_endpoint.address must be specified with local_endpoint.netmask.
66257126
The remote_endpoint.address must be specified with remote_endpoint.netmask.
66257127
The local subnet must be configured as a non-zero subnet.
66257128
Invalid ANY wildcard subnet.
66257129
A specific local or remote port number is required when the remote subnet is configured as an ANY wildcard subnet.
66257131
ESP in UDPv6 Encapsulation is not supported.
66257135
The specified certificate is not found on the SVM.
66257136
A certificate is not needed for the PSK authentication method.
66257138
Remote identity is required when using certificate verification.
66257139
Certificate with the specified UUID was not found.
66257140
Only certificates with a client or server type are supported.
66257142
Failed to create IPsec policy because the specified SVM is being migrated.
66257143
Invalid IPsec policy provided. The subnet must be non-empty.
66257153
The policy requires a post-quantum pre-shared key because ppk-identity is specified for this policy.
66257154
The policy requires a post-quantum pre-shared identity because ppk-shared-key is specified for this policy.
66257199
Not all of the nodes in the cluster are running a version that supports the IPsec feature.
66257200
The shared key does not meet required ASCII-range characters length.
66257201
Support for the feature available with effective cluster version or later.
66257305
The certificate UUID does not match the provided certificate name.
string
certificate
name
string
Certificate name
uuid
string
Certificate UUID
ipspace
Applies to both SVM and cluster-scoped objects. Either the UUID or name may be supplied on input.
name
string
IPspace name
uuid
string
IPspace UUID
local_endpoint
address
string
IPv4 or IPv6 address
netmask
string
Input as netmask length (16) or IPv4 mask (255.255.0.0). For IPv6, the default value is 64 with a valid range of 1 to 127. Output is always the netmask length.
port
string
Application port to be covered by the IPsec policy
ppk
identity
string
Post-quantum pre-shared key identity.
remote_endpoint
address
string
netmask
string
port
string
svm
name
string
uuid
string
ipsec_policy
IPsec policy object.
certificate
certificate
boolean
enabled
boolean
local_endpoint
local_endpoint
local_identity
string
Local Identity
ppk
ppk
protocol
string
remote_endpoint
remote_endpoint
remote_identity
string
Remote Identity
uuid
string
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
