REST API reference
Update the software FIPS mode or enable conversion of non-encrypted metadata volumes non-NAE aggregates
Updates the software FIPS mode or enables conversion of non-encrypted metadata volumes and aggregates. Use this endpoint to manage encryption settings for data security compliance.
HTTP method and endpoint
PATCH /security
Introduced in
ONTAP 9.8
Usage notes
Updates the software FIPS mode or enables conversion of non-encrypted metadata volumes to encrypted metadata volumes and non-NAE aggregates to NAE aggregates.
  • security config modify
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
fips
fips
Cluster-wide Federal Information Processing Standards (FIPS) mode information.
management_protocols
Cluster-wide security protocols related information.
software_data_encryption
Cluster-wide software data encryption related information.
tls
tls
Cluster-wide Transport Layer Security (TLS) configuration information
Example request
  "tls": {
    "cipher_suites": [
      "TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384"
    "protocol_versions": [
      "string"
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
5636142
This operation is not supported in a mixed-release cluster.
5636145
This operation is not supported when cluster security is configured with FIPS mode.
52428817
SSLv3 is not supported when FIPS is enabled.
52428824
TLSv1 is not supported when FIPS is enabled.
52428830
Cannot enable FIPS-compliant mode because the configured minimum security strength for certificates is not compatible.
52428832
TLSv1.1 is not supported when FIPS is enabled.
52559974
Cannot enable FIPS-compliant mode because a certificate that is not FIPS-compliant is in use.
196608081
Cannot start software encryption conversion while there are data volumes in the cluster.
196608082
The operation is not valid when the MetroCluster is in switchover mode.
string
fips
enabled
boolean
Indicates whether or not the software FIPS mode is enabled on the cluster. Our FIPS compliance involves configuring the use of only approved algorithms in applicable contexts (for example TLS), as well as the use of formally validated cryptographic module software implementations, where applicable. The US government documents concerning FIPS 140-2 outline the relevant security policies in detail.
rsh_enabled
boolean
Indicates whether or not security protocol rsh is enabled on the cluster.
telnet_enabled
boolean
Indicates whether or not security protocol telnet is enabled on the cluster.
onboard_key_manager_configurable_status
Indicates whether the Onboard Key Manager can be configured in the cluster.
code
integer
Code corresponding to the status message. Returns a 0 if the Onboard Key Manager can be configured in the cluster.
message
string
Reason that Onboard Key Manager cannot be configured in the cluster.
supported
boolean
Set to true if the Onboard Key Manager can be configured in the cluster.
conversion_enabled
boolean
Indicates whether or not software encryption conversion is enabled on the cluster. A PATCH request initiates the conversion of all non-encrypted metadata volumes in the cluster to encrypted metadata volumes and all non-NAE aggregates to NAE aggregates. For the PATCH request to start, the cluster must have either an Onboard or an external key manager set up and the aggregates should either be empty or have only metadata volumes. No data volumes should be present in any of the aggregates in the cluster. For MetroCluster configurations, a PATCH request enables conversion on all the aggregates and metadata volumes of both local and remote clusters and is not allowed when the MetroCluster is in switchover state.
disabled_by_default
boolean
Indicates whether or not default software data at rest encryption is disabled on the cluster.
tls
cipher_suites
array[string]
Names a cipher suite that the system can select during TLS handshakes. A list of available options can be found on the Internet Assigned Number Authority (IANA) website.
protocol_versions
array[string]
Names a TLS protocol version that the system can select during TLS handshakes. The use of SSLv3 or TLSv1 is discouraged.
security_config
fips
fips
tls
tls
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
