Update the software FIPS mode or enable conversion of non-encrypted metadata volumes non-NAE aggregates
Updates the software FIPS mode or convert non-encrypted metadata volumes to encrypted metadata volumes. This action is useful for enhancing data security by modifying software data encryption settings and enabling conversion to NAE aggregates.
HTTP method and endpoint
PATCH /security
Introduced in
ONTAP 9.8
Usage notes
Updates the software FIPS mode or modifies software data encryption. The PATCH request can be used to enable conversion of non-encrypted metadata volumes to encrypted metadata volumes and non-NAE aggregates to NAE aggregates.
Related ONTAP commands
security config modify
return_timeout |
integer |
query |
False |
Request Body
| Name | Type | Description |
fips |
Cluster-wide Federal Information Processing Standards (FIPS) mode information. |
management_protocols |
Cluster-wide security protocols related information. |
software_data_encryption |
Cluster-wide software data encryption related information. |
tls |
Cluster-wide Transport Layer Security (TLS) configuration information |
Example request
"software_data_encryption": {
"encryption_state": "string"
"tls": {
"cipher_suites": [
"TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384"
"protocol_versions": [
"string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
5636142 |
This operation is not supported in a mixed-release cluster. |
5636145 |
This operation is not supported when cluster security is configured with FIPS mode. |
52428817 |
SSLv3 is not supported when FIPS is enabled. |
52428824 |
TLSv1 is not supported when FIPS is enabled. |
52428830 |
Cannot enable FIPS-compliant mode because the configured minimum security strength for certificates is not compatible. |
52428832 |
TLSv1.1 is not supported when FIPS is enabled. |
52559974 |
Cannot enable FIPS-compliant mode because a certificate that is not FIPS-compliant is in use. |
65536987 |
One or more key servers are unavailable. |
196608047 |
Operation is not allowed when volume move is in progress. |
196608070 |
Key manager is not configured on the cluster. Configure either an external Key Management Server or an onboard key manager. |
196608081 |
Cannot start software encryption conversion while there are data volumes in the cluster. |
196608082 |
The operation is not valid when the MetroCluster is in switchover mode. |
196608368 |
Failed to perform the requested operation. One or more data volume in offline state. |
196608369 |
Conversion cannot be enabled because the cluster contains read-only or primordial logical data-protection volumes. Retry the patch operation after deleting those volumes. |
196608370 |
The conversion of non-encrypted volumes to NVE (NetApp Volume Encryption) volumes is already running. Monitor the NVE conversion status by querying the "software_data_encryption.encryption_state" field on the "/api/security" endpoint. |
196608371 |
NVE (NetApp Volume Encryption) volumes are already being rekeyed. Monitor the NVE rekey status by querying the "software_data_encryption.encryption_state" field on the "/api/security" endpoint. |
196608372 |
An automated ONTAP update is in progress, retry the PATCH request after it is completed. |
196608373 |
Unable to perform the encryption operation because of a mixed-release cluster. Complete the upgrade or revert operation, then try the PATCH request again. |
196608374 |
Failed to perform the requested operation. One or more SVMs not in admin running state. |
196608375 |
Failed to perform the requested operation. One or more volume is of temporary type. |
196608376 |
Internal error. Could not get volume encryption information. |
196608377 |
Internal error. The Volume Location Database (VLDB) is inconsistent. Contact support personnel to resolve this issue. |
196608378 |
Failed to perform the requested operation. Data SVM Key manager configuration is in mixed state. |
196608379 |
Internal error. The encryption metadata for the volume is inconsistent. Contact technical support for assistance. |
196608380 |
Failed to perform the requested operation. Wafliron is currently active. |
196608381 |
Failed to perform the requested operation. A clone split operation is in progress. |
196608382 |
Failed to perform the requested operation. A volume rehost operation is in progress. |
196608383 |
Failed to perform the requested operation. The cluster contains one or more SnapLock volume. |
196608384 |
The PATCH request to start rekey failed because the cluster contains one or more plain text volumes. Retry the PATCH request after converting the existing plain text volumes to encrypted volumes. |
196608385 |
Failed to perform the requested operation. Keystore configuration is being switched. Wait until the keystore is in the active state and then try the PATCH request again. |
196608386 |
Failed to perform the requested operation. Rekey operation for one or more SVMs is in progress. Wait until the keystore is in the active state and then try the PATCH request again. |
196608387 |
"software_data_encryption.conversion_enabled" cannot be set to "false" in a PATCH request. |
196608388 |
Both "software_data_encryption.conversion_enabled" and "software_data_encryption.disabled_by_default" cannot be set to "true" in a single PATCH request. |
196608389 |
Both "software_data_encryption.conversion_enabled" and "software_data_encryption.rekey" cannot be set to "true" in a single PATCH request. |
196608390 |
"software_data_encryption.rekey" cannot be set to "false" in a PATCH request. |
196608391 |
Both "software_data_encryption.rekey" and "software_data_encryption.disabled_by_default" cannot be set to "true" in a single PATCH request. |
196608392 |
The PATCH request for cluster level rekey requires an effective cluster version of 9.16.1 or later. |
196608393 |
The PATCH request for cluster level rekey is not supported on this platform. |
href |
string |
_links
fips
enabled |
boolean |
Indicates whether or not the software FIPS mode is enabled on the cluster. Our FIPS compliance involves configuring the use of only approved algorithms in applicable contexts (for example TLS), as well as the use of formally validated cryptographic module software implementations, where applicable. The US government documents concerning FIPS 140-2 outline the relevant security policies in detail. |
rsh_enabled |
boolean |
Indicates whether or not security protocol rsh is enabled on the cluster. |
telnet_enabled |
boolean |
Indicates whether or not security protocol telnet is enabled on the cluster. |
onboard_key_manager_configurable_status
Indicates whether the Onboard Key Manager can be configured in the cluster.
code |
integer |
Code corresponding to the status message. Returns a 0 if the Onboard Key Manager can be configured in the cluster. |
message |
string |
Reason that Onboard Key Manager cannot be configured in the cluster. |
supported |
boolean |
Set to true if the Onboard Key Manager can be configured in the cluster. |
conversion_enabled |
boolean |
Indicates whether or not software encryption conversion is enabled on the cluster. A PATCH request initiates the conversion of all non-encrypted metadata volumes in the cluster to encrypted metadata volumes and all non-NAE aggregates to NAE aggregates. For the PATCH request to start, the cluster must have either an Onboard or an external key manager set up and the aggregates should either be empty or have only metadata volumes. No data volumes should be present in any of the aggregates in the cluster. For MetroCluster configurations, a PATCH request enables conversion on all the aggregates and metadata volumes of both local and remote clusters and is not allowed when the MetroCluster is in switchover state. |
disabled_by_default |
boolean |
Indicates whether or not default software data at rest encryption is disabled on the cluster. |
encryption_state |
string |
Software data encryption state. encrypted ‐ All the volumes are encrypted. encrypting ‐ Encryption conversion operation is in progress. partial ‐ Some volumes are encrypted, and others remains in plain text. rekeying ‐ All volumes are currently being encrypted with a new key. unencrypted ‐ None of the volumes are encrypted. conversion_paused ‐ Encryption conversion operation is paused on one or more volumes. rekey_paused ‐ Encryption rekey operation is paused on one or more volumes. |
rekey |
boolean |
tls
cipher_suites |
array[string] |
Names a cipher suite that the system can select during TLS handshakes. A list of available options can be found on the Internet Assigned Number Authority (IANA) website. |
offload_enabled |
boolean |
Indicates whether or not TLS hardware offload is enabled. |
protocol_versions |
array[string] |
Names a TLS protocol version that the system can select during TLS handshakes. The use of SSLv3 or TLSv1 is discouraged. |
security_config
fips |
tls |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
