REST API reference
Update the software FIPS mode or enable conversion of non-encrypted metadata volumes non-NAE aggregates
Updates the software FIPS mode to enhance security or convert non-encrypted metadata volumes and aggregates to their encrypted counterparts.
HTTP method and endpoint
PATCH /security
Introduced in
ONTAP 9.8
Usage notes
Updates the software FIPS mode or modifies software data encryption.
Platform Specifics
Unified ONTAP
The PATCH request can be used to enable conversion of non-encrypted metadata volumes to encrypted metadata volumes and non-NAE aggregates to NAE aggregates.
  • security config modify
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
Request Body
Name Type Description
fips
fips
Cluster-wide Federal Information Processing Standards (FIPS) mode information.
management_protocols
Cluster-wide security protocols related information.
software_data_encryption
Cluster-wide software data encryption related information.
tls
tls
Cluster-wide Transport Layer Security (TLS) configuration information
Example request
  "software_data_encryption": {
    "encryption_state": "string"
  "tls": {
    "cipher_suites": [
      "TLS_ECDHE_RSA_WITH_AES_256_GCM_SHA384"
    "protocol_versions": [
      "string"
Status: 200, Ok
job
job_link
  "job": {
    "uuid": "string"
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
Error Code Description
5636142
This operation is not supported in a mixed-release cluster.
5636145
This operation is not supported when cluster security is configured with FIPS mode.
52428817
SSLv3 is not supported when FIPS is enabled.
52428824
TLSv1 is not supported when FIPS is enabled.
52428830
Cannot enable FIPS-compliant mode because the configured minimum security strength for certificates is not compatible.
52428832
TLSv1.1 is not supported when FIPS is enabled.
52559974
Cannot enable FIPS-compliant mode because a certificate that is not FIPS-compliant is in use.
65536987
One or more key servers are unavailable.
196608047
Operation is not allowed when volume move is in progress.
196608070
Key manager is not configured on the cluster. Configure either an external Key Management Server or an onboard key manager.
196608081
Cannot start software encryption conversion while there are data volumes in the cluster.
196608082
The operation is not valid when the MetroCluster is in switchover mode.
196608368
Failed to perform the requested operation. One or more data volume in offline state.
196608369
Conversion cannot be enabled because the cluster contains read-only or primordial logical data-protection volumes. Retry the patch operation after deleting those volumes.
196608370
The PATCH request to enable conversion failed because one or more volumes are already queued for the encryption conversion operation.
196608372
An automated ONTAP update is in progress, retry the PATCH request after it is completed.
196608373
Unable to perform the encryption operation because of a mixed-release cluster. Complete the upgrade or revert operation, then try the PATCH request again.
196608374
Failed to perform the requested operation. One or more SVMs not in admin running state.
196608375
Failed to perform the requested operation. One or more volume is of temporary type.
196608376
Internal error. Could not get volume encryption information.
196608377
Internal error. The Volume Location Database (VLDB) is inconsistent. Contact support personnel to resolve this issue.
196608378
Failed to perform the requested operation. Data SVM Key manager configuration is in mixed state.
196608379
Internal error. The encryption metadata for the volume is inconsistent. Contact technical support for assistance.
196608380
Failed to perform the requested operation. Wafliron is currently active.
196608381
Failed to perform the requested operation. A clone split operation is in progress.
196608382
Failed to perform the requested operation. A volume rehost operation is in progress.
196608383
Failed to perform the requested operation. The cluster contains one or more SnapLock volume.
196608384
The PATCH request to start rekey failed because the cluster contains one or more plain text volumes. Retry the PATCH request after converting the existing plain text volumes to encrypted volumes.
196608385
Failed to perform the requested operation. Keystore configuration is being switched. Wait until the keystore is in the active state and then try the PATCH request again.
196608386
Failed to perform the requested operation. Rekey operation for one or more SVMs is in progress. Wait until the keystore is in the active state and then try the PATCH request again.
196608387
"software_data_encryption.conversion_enabled" cannot be set to "false" in a PATCH request.
196608388
Both "software_data_encryption.conversion_enabled" and "software_data_encryption.disabled_by_default" cannot be set to "true" in a single PATCH request.
196608389
Both "software_data_encryption.conversion_enabled" and "software_data_encryption.rekey" cannot be set to "true" in a single PATCH request.
196608390
"software_data_encryption.rekey" cannot be set to "false" in a PATCH request.
196608391
Both "software_data_encryption.rekey" and "software_data_encryption.disabled_by_default" cannot be set to "true" in a single PATCH request.
196608392
The PATCH request for cluster level rekey requires an effective cluster version of 9.16.1 or later.
196608393
The PATCH request for cluster level rekey is not supported on this platform.
string
fips
enabled
boolean
Indicates whether or not the software FIPS mode is enabled on the cluster. Our FIPS compliance involves configuring the use of only approved algorithms in applicable contexts (for example TLS), as well as the use of formally validated cryptographic module software implementations, where applicable. The US government documents concerning FIPS 140-2 outline the relevant security policies in detail.
rsh_enabled
boolean
Indicates whether or not security protocol rsh is enabled on the cluster.
telnet_enabled
boolean
Indicates whether or not security protocol telnet is enabled on the cluster.
onboard_key_manager_configurable_status
Indicates whether the Onboard Key Manager can be configured in the cluster.
code
integer
Code corresponding to the status message. Returns a 0 if the Onboard Key Manager can be configured in the cluster.
message
string
Reason that Onboard Key Manager cannot be configured in the cluster.
supported
boolean
Set to true if the Onboard Key Manager can be configured in the cluster.
conversion_enabled
boolean
Indicates whether or not software encryption conversion is enabled on the cluster. A PATCH request initiates the conversion of all non-encrypted metadata volumes in the cluster to encrypted metadata volumes and all non-NAE aggregates to NAE aggregates. For the PATCH request to start, the cluster must have either an Onboard or an external key manager set up and the aggregates should either be empty or have only metadata volumes. No data volumes should be present in any of the aggregates in the cluster. For MetroCluster configurations, a PATCH request enables conversion on all the aggregates and metadata volumes of both local and remote clusters and is not allowed when the MetroCluster is in switchover state.
disabled_by_default
boolean
Indicates whether or not default software data at rest encryption is disabled on the cluster.
encryption_state
string
Software data encryption state. encrypted ‐ All the volumes are encrypted. encrypting ‐ Encryption conversion operation is in progress. partial ‐ Some volumes are encrypted, and others remains in plain text. rekeying ‐ All volumes are currently being encrypted with a new key. unencrypted ‐ None of the volumes are encrypted. conversion_paused ‐ Encryption conversion operation is paused on one or more volumes. rekey_paused ‐ Encryption rekey operation is paused on one or more volumes.
rekey
boolean
tls
cipher_suites
array[string]
Names a cipher suite that the system can select during TLS handshakes. A list of available options can be found on the Internet Assigned Number Authority (IANA) website.
protocol_versions
array[string]
Names a TLS protocol version that the system can select during TLS handshakes. The use of SSLv3 or TLSv1 is discouraged.
security_config
fips
fips
tls
tls
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
