Update an event filter rule
PATCH /support/ems/filters/{name}/rules/{index}
Introduced In: 9.6
Updates an event filter rule.
Recommended optional properties
message_criteria- Message criteria used by a rule to match an event. -
parameter_criteria- Parameter criteria used by a rule to match an event.
Related ONTAP commands
event filter rule add -
event filter rule delete
name |
string |
path |
True |
Filter name |
index |
string |
path |
True |
Filter rule index |
new_index |
integer |
query |
False |
New position for the filter rule index |
Request Body
| Name | Type | Description |
index |
integer |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list. |
message_criteria |
Matching message definitions for the filter. A property must be specified. |
parameter_criteria |
array[parameter_criteria] |
Parameter criteria used to match against events' parameters. Each parameter consists of a name and a value. When multiple parameter criteria are provided in a rule, all must match for the rule to be considered matched. A pattern can include one or more wildcard '*' characters. |
type |
string |
Rule type |
Example request
"index": 1,
"message_criteria": {
"name_pattern": "wafl.*",
"severities": "emergency,alert,error",
"snmp_trap_types": "standard,built_in"
"parameter_criteria": [
"name_pattern": "vol",
"value_pattern": "cloud*"
"type": "include"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983092 |
The index of the rule provided is outside the allowed range for the filter provided |
983095 |
The rule index provided is invalid for the filter provided |
983113 |
Default filters cannot be modified or removed |
983126 |
A rule requires at least one name_pattern, severities, snmp_trap_types, or parameter pattern to be defined |
983127 |
A property cannot contain a combination of the wildcard characters and other values. |
983128 |
An invalid value is provided for the property 'snmp_trap_types' |
983146 |
An invalid value is provided for the property 'severities' |
983147 |
The severities provided are not supported |
983155 |
The provided severities property does not match that of the name_pattern |
983156 |
The provided snmp_trap_types property does not match that of the name_pattern |
983157 |
The provided severities and snmp_trap_types properties do not match those of the name_pattern |
983158 |
The name_pattern provided does not exist |
983195 |
Empty field in parameter_criteria. Both name and value patterns must be specified |
983196 |
name_pattern and value_pattern fields in parameter_criteria are empty |
983211 |
Parameter criteria based filtering is not supported in this version of ONTAP |
href |
string |
_links
message_criteria
name_pattern |
string |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified. |
severities |
string |
A comma-separated list of severities or a wildcard. |
snmp_trap_types |
string |
A comma separated list of snmp_trap_types or a wildcard. |
parameter_criteria
Criterion used for parameter based filtering
name_pattern |
string |
Parameter name pattern. Wildcard character '*' is supported. |
value_pattern |
string |
Parameter value pattern. Wildcard character '*' is supported. |
ems_filter_rule
Rule for an event filter
index |
integer |
message_criteria |
type |
string |
Rule type |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
