Update an event filter rule
Updates an event filter rule to modify the criteria used to match events based on specific message or parameter attributes. Use this to refine event handling and ensure relevant events are captured according to your needs.
HTTP method and endpoint
PATCH /support/ems/filters/{name}/rules/{index}
Introduced in
ONTAP 9.6
Recommended optional properties
message_criteria- Message criteria used by a rule to match an event. -
parameter_criteria- Parameter criteria used by a rule to match an event.
Related ONTAP commands
event filter rule add -
event filter rule delete
name |
string |
path |
True |
Filter name |
index |
string |
path |
True |
Filter rule index |
new_index |
integer |
query |
False |
New position for the filter rule index |
Request Body
| Name | Type | Description |
index |
integer |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list. |
message_criteria |
Matching message definitions for the filter. A property must be specified. |
parameter_criteria |
array[parameter_criteria] |
Parameter criteria used to match against events' parameters. Each parameter consists of a name and a value. When multiple parameter criteria are provided in a rule, all must match for the rule to be considered matched. A pattern can include one or more wildcard '*' characters. |
type |
string |
Rule type |
Example request
"index": 1,
"message_criteria": {
"name_pattern": "wafl.*",
"severities": "emergency,alert,error",
"snmp_trap_types": "standard,built_in"
"parameter_criteria": [
"name_pattern": "vol",
"value_pattern": "cloud*"
"type": "include"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983092 |
The index of the rule provided is outside the allowed range for the filter provided |
983095 |
The rule index provided is invalid for the filter provided |
983113 |
Default filters cannot be modified or removed |
983126 |
A rule requires at least one name_pattern, severities, snmp_trap_types, or parameter pattern to be defined |
983127 |
A property cannot contain a combination of the wildcard characters and other values. |
983128 |
An invalid value is provided for the property 'snmp_trap_types' |
983146 |
An invalid value is provided for the property 'severities' |
983147 |
The severities provided are not supported |
983155 |
The provided severities property does not match that of the name_pattern |
983156 |
The provided snmp_trap_types property does not match that of the name_pattern |
983157 |
The provided severities and snmp_trap_types properties do not match those of the name_pattern |
983158 |
The name_pattern provided does not exist |
983195 |
Empty field in parameter_criteria. Both name and value patterns must be specified |
983196 |
name_pattern and value_pattern fields in parameter_criteria are empty |
983211 |
Parameter criteria based filtering is not supported in this version of ONTAP |
href |
string |
_links
message_criteria
name_pattern |
string |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified. |
severities |
string |
A comma-separated list of severities or a wildcard. |
snmp_trap_types |
string |
A comma separated list of snmp_trap_types or a wildcard. |
parameter_criteria
Criterion used for parameter based filtering
name_pattern |
string |
Parameter name pattern. Wildcard character '*' is supported. |
value_pattern |
string |
Parameter value pattern. Wildcard character '*' is supported. |
ems_filter_rule
Rule for an event filter
index |
integer |
message_criteria |
type |
string |
Rule type |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
