Update an event filter rule
PATCH /support/ems/filters/{name}/rules/{index}
Introduced In: 9.6
Updates an event filter rule.
Recommended optional properties
message_criteria- New criteria on which a rule is to match an event.
Related ONTAP commands
event filter rule add -
event filter rule delete
name |
string |
path |
True |
Filter name |
index |
string |
path |
True |
Filter index |
new_index |
integer |
query |
False |
New position for the filter rule index |
Request Body
| Name | Type | Description |
index |
integer |
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list. |
message_criteria |
Matching message definitions for the filter. A property must be specified. |
type |
string |
Rule type |
Example request
"index": "1",
"message_criteria": {
"name_pattern": "callhome.*",
"severities": "error,informational",
"snmp_trap_types": "standard|built_in"
"type": "include"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
983092 |
The index of the rule provided is outside the allowed range for the filter provided |
983095 |
The rule index provided is invalid for the filter provided |
983113 |
Default filters cannot be modified or removed |
983126 |
A rule requires at least one name_pattern, severities, or snmp_trap_types to be defined |
983127 |
A property cannot contain a combination of the wildcard characters and other values. |
983128 |
An invalid value is provided for the property 'snmp_trap_types' |
983146 |
An invalid value is provided for the property 'severities' |
983147 |
The severity levels provided are not supported |
983155 |
The provided severities property does not match that of the name_pattern |
983156 |
The provided snmp_trap_types property does not match that of the name_pattern |
983157 |
The provided severities and snmp_trap_types do not match those of the name_pattern |
983158 |
The name_pattern provided does not exist |
href |
string |
_links
message_criteria
name_pattern |
string |
Message name filter on which to match. Supports wildcards. Defaults to * if not specified. |
severities |
string |
A comma-separated list of severities or a wildcard. |
snmp_trap_types |
string |
A comma separated list of snmp_trap_types or a wildcard. |
ems_filter_rule
Rule for an event filter
index |
integer |
message_criteria |
type |
string |
Rule type |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
