REST API reference
Update an event filter rule
Updates an event filter rule to modify the criteria on which the rule matches an event. This allows you to refine how events are filtered based on the latest requirements.
HTTP method and endpoint
PATCH /support/ems/filters/{name}/rules/{index}
Introduced in
ONTAP 9.6
  • message_criteria - New criteria on which a rule is to match an event.
  • event filter rule add
  • event filter rule delete
name
string
path
True
Filter name
index
string
path
True
Filter index
new_index
integer
query
False
New position for the filter rule index
Request Body
Name Type Description
index
integer
Rule index. Rules are evaluated in ascending order. If a rule's index order is not specified during creation, the rule is appended to the end of the list.
message_criteria
message_criteria
Matching message definitions for the filter. A property must be specified.
type
string
Rule type
Example request
  "index": "1",
  "message_criteria": {
    "name_pattern": "callhome.*",
    "severities": "error,informational",
    "snmp_trap_types": "standard|built_in"
  "type": "include"
Status: 200, Ok
Status: Default
ONTAP Error Response Codes
Error Code Description
983092
The index of the rule provided is outside the allowed range for the filter provided
983095
The rule index provided is invalid for the filter provided
983113
Default filters cannot be modified or removed
983126
A rule requires at least one name_pattern, severities, or snmp_trap_types to be defined
983127
A property cannot contain a combination of the wildcard characters and other values.
983128
An invalid value is provided for the property 'snmp_trap_types'
983146
An invalid value is provided for the property 'severities'
983147
The severity levels provided are not supported
983155
The provided severities property does not match that of the name_pattern
983156
The provided snmp_trap_types property does not match that of the name_pattern
983157
The provided severities and snmp_trap_types do not match those of the name_pattern
983158
The name_pattern provided does not exist
string
message_criteria
name_pattern
string
Message name filter on which to match. Supports wildcards. Defaults to * if not specified.
severities
string
A comma-separated list of severities or a wildcard.
snmp_trap_types
string
A comma separated list of snmp_trap_types or a wildcard.
ems_filter_rule
Rule for an event filter
index
integer
message_criteria
message_criteria
type
string
Rule type
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
