Create and connect an ONTAP Mediator
POST /cluster/mediators
Introduced In: 9.8
Creates and connect a mediator.
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
ca_certificate |
string |
CA certificate for ONTAP Mediator. This is optional if the certificate is already installed.
dr_group |
DR group reference. |
ip_address |
string |
The IP address of the mediator. |
password |
string |
The password used to connect to the REST server on the mediator. |
peer_cluster |
The peer cluster that the mediator service is used for. |
peer_mediator_connectivity |
string |
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown. |
port |
integer |
The REST server's port number on the mediator. |
reachable |
boolean |
Indicates the connectivity status of the mediator. |
user |
string |
The username used to connect to the REST server on the mediator. |
uuid |
string |
The unique identifier for the mediator service. |
Example request
"ca_certificate": "string",
"dr_group": {
"id": 0
"ip_address": "10.10.10.7",
"password": "mypassword",
"peer_cluster": {
"name": "cluster2",
"uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
"peer_mediator_connectivity": "connected",
"port": 31784,
"reachable": 1,
"user": "myusername",
"uuid": "string"
Status: 202, Accepted
job |
"job": {
"uuid": "string"
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: 201, Created
Status: Default
ONTAP Error Response codes
| Error code | Description |
13369351 |
Update to mediator failed. Reason: does not authorized for that command. Check that the peer cluster and mediator are reachable. |
2430758 |
Mediator cannot be added. Reason: Some of the nodes in the cluster have incorrect MetroCluster IP configuration. |
2430734 |
Unable to add Mediator. Reason : Authentication failed. |
2430774 |
Failed to add Mediator. Reason : Node is not reachable or does not exist. |
2432871 |
Failed to add Mediator. Reason : Some of the parameters in the request is invalid. |
dr_group
DR group reference.
id |
integer |
DR Group ID |
href |
string |
_links
peer_cluster
name |
string |
uuid |
string |
mediator
Mediator information
ca_certificate |
string |
dr_group |
ip_address |
string |
password |
string |
peer_cluster |
string |
port |
integer |
reachable |
boolean |
user |
string |
uuid |
string |
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
