REST API reference
Create and connect an ONTAP Mediator
Creates and connects an ONTAP Mediator, establishing a link for managing and coordinating operations between different storage systems.
HTTP method and endpoint
POST /cluster/mediators
Introduced in
ONTAP 9.8
Usage notes
Creates and connect a mediator.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
account_token
string
NetApp Console account token. This field is only applicable to the ONTAP cloud mediator.
  • x-ntap-createOnly: true
  • Introduced in: 9.19
  • x-nullable: true
bluexp_account_token
string
BlueXP account token. This field is only applicable to the ONTAP cloud mediator. This has been replaced by account_token. Support for this field will be removed in a future release.
  • x-ntap-deprecated: 9.19.1
  • Introduced in: 9.17
  • x-nullable: true
bluexp_org_id
string
BlueXP organization ID. This field is only applicable to the ONTAP cloud mediator. This has been replaced by org_id. Support for this field will be removed in a future release.
  • x-nullable: true
ca_certificate
string
CA certificate for ONTAP Mediator. This is optional if the certificate is already installed.
  • Introduced in: 9.8
  • x-nullable: true
connection_type
string
Connection type from ONTAP MetroCluster to mediator. Applicable only to on-prem mediator used in ONTAP MetroCluster configurations.
  • Default value: 1
  • enum: ["iscsi_mediator", "https_mediator"]
  • readCreate: 1
  • x-nullable: true
dr_group
dr_group
DR group reference.
ip_address
string
The IP address of the mediator.
local_mediator_connectivity
string
Indicates the mediator connectivity status of the local cluster. Possible values are connected, unreachable, unusable and down-high-latency. This field is only applicable to the mediators in SnapMirror active sync configuration.
org_id
string
NetApp Console organization ID. This field is only applicable to the ONTAP cloud mediator.
  • x-nullable: true
password
string
The password used to connect to the REST server on the mediator.
peer_cluster
peer_cluster
The peer cluster that the mediator service is used for.
peer_mediator_connectivity
string
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown and down-high-latency.
port
integer
The REST server's port number on the mediator.
reachable
boolean
Indicates the connectivity status of the mediator.
service_account_client_id
string
Client ID of the NetApp Console service account. This field is only applicable to the ONTAP cloud mediator.
  • x-nullable: true
service_account_client_secret
string
Client secret token of the NetApp Console service account. This field is only applicable to the ONTAP cloud mediator.
  • x-nullable: true
strict_cert_validation
boolean
Indicates if strict validation of certificates is performed while making REST API calls to the mediator. This field is only applicable to the ONTAP Cloud Mediator.
  • Default value: 1
  • example: true
  • x-nullable: true
type
string
Mediator type. This field is only applicable to the mediators in SnapMirror active sync configuration.
use_http_proxy_local
boolean
Indicates if the local cluster should use an http-proxy server while making REST API calls to the mediator. This field is only applicable to the ONTAP cloud mediator.
  • Default value: 1
  • example: true
  • x-nullable: true
use_http_proxy_remote
boolean
Indicates if the remote cluster should use an http-proxy server while making REST API calls to the mediator. This field is only applicable to the ONTAP cloud mediator.
  • Default value: 1
  • example: true
  • writeOnly: 1
  • x-nullable: true
user
string
The username used to connect to the REST server on the mediator.
uuid
string
The unique identifier for the mediator service.
Example request
  "account_token": "string",
  "bluexp_account_token": "string",
  "bluexp_org_id": "string",
  "ca_certificate": "string",
  "connection_type": "string",
  "dr_group": {
    "id": 0
  "ip_address": "10.10.10.7",
  "local_mediator_connectivity": "connected",
  "org_id": "string",
  "password": "mypassword",
  "peer_cluster": {
    "name": "cluster2",
    "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
  "peer_mediator_connectivity": "connected",
  "port": 31784,
  "reachable": 1,
  "service_account_client_id": "string",
  "service_account_client_secret": "string",
  "strict_cert_validation": 1,
  "type": "string",
  "use_http_proxy_local": 1,
  "use_http_proxy_remote": 1,
  "user": "myusername",
  "uuid": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response codes
Error code Description
13369351
Update to mediator failed. Reason: does not authorized for that command. Check that the peer cluster and mediator are reachable.
2430758
Mediator cannot be added. Reason: Some of the nodes in the cluster have incorrect MetroCluster IP configuration.
2430734
Unable to add Mediator. Reason : Authentication failed.
2430774
Failed to add Mediator. Reason : Node is not reachable or does not exist.
2432871
Failed to add Mediator. Reason : Some of the parameters in the request is invalid.
dr_group
DR group reference.
id
integer
DR Group ID
string
peer_cluster
name
string
uuid
string
mediator
Mediator information
account_token
string
  • x-nullable: true
string
  • x-nullable: true
bluexp_org_id
string
  • x-nullable: true
ca_certificate
string
  • x-nullable: true
connection_type
string
  • Default value: 1
  • readCreate: 1
  • x-nullable: true
dr_group
dr_group
DR group reference.
ip_address
string
string
org_id
string
  • x-nullable: true
password
string
peer_cluster
peer_cluster
string
port
integer
reachable
boolean
string
  • x-nullable: true
string
  • x-nullable: true
boolean
  • Default value:
  • example: true
  • x-nullable: true
type
string
boolean
  • Default value:
  • example: true
  • x-nullable: true
boolean
  • Default value:
  • example: true
  • writeOnly: 1
  • x-nullable: true
user
string
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
