REST API reference
Create and connect an ONTAP Mediator
Creates and connects an ONTAP Mediator, establishing a link for managing and coordinating operations between different storage systems.
HTTP method and endpoint
POST /cluster/mediators
Introduced in
ONTAP 9.8
Usage notes
Creates and connect a mediator.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
ca_certificate
string
CA certificate for ONTAP Mediator. This is optional if the certificate is already installed.
  • x-ntap-createOnly: true
  • Introduced in: 9.8
  • x-nullable: true
dr_group
dr_group
DR group reference.
ip_address
string
The IP address of the mediator.
password
string
The password used to connect to the REST server on the mediator.
peer_cluster
peer_cluster
The peer cluster that the mediator service is used for.
peer_mediator_connectivity
string
Indicates the mediator connectivity status of the peer cluster. Possible values are connected, unreachable, unknown.
port
integer
The REST server's port number on the mediator.
reachable
boolean
Indicates the connectivity status of the mediator.
user
string
The username used to connect to the REST server on the mediator.
uuid
string
The unique identifier for the mediator service.
Example request
  "ca_certificate": "string",
  "dr_group": {
    "id": 0
  "ip_address": "10.10.10.7",
  "password": "mypassword",
  "peer_cluster": {
    "name": "cluster2",
    "uuid": "ebe27c49-1adf-4496-8335-ab862aebebf2"
  "peer_mediator_connectivity": "connected",
  "port": 31784,
  "reachable": 1,
  "user": "myusername",
  "uuid": "string"
Status: 202, Accepted
job
job_link
  "job": {
    "uuid": "string"
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: 201, Created
Status: Default
ONTAP Error Response codes
Error code Description
13369351
Update to mediator failed. Reason: does not authorized for that command. Check that the peer cluster and mediator are reachable.
2430758
Mediator cannot be added. Reason: Some of the nodes in the cluster have incorrect MetroCluster IP configuration.
2430734
Unable to add Mediator. Reason : Authentication failed.
2430774
Failed to add Mediator. Reason : Node is not reachable or does not exist.
2432871
Failed to add Mediator. Reason : Some of the parameters in the request is invalid.
dr_group
DR group reference.
id
integer
DR Group ID
string
peer_cluster
name
string
uuid
string
mediator
Mediator information
ca_certificate
string
  • x-nullable: true
dr_group
dr_group
DR group reference.
ip_address
string
password
string
peer_cluster
peer_cluster
string
port
integer
reachable
boolean
user
string
uuid
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
