Create a local UNIX group configuration for an SVM
Creates a local UNIX group configuration for a specified SVM. Use this when you need to define group settings and identifiers to manage SVM permissions and access.
HTTP method and endpoint
POST /name-services/unix-groups
Introduced in
ONTAP 9.9
Usage notes
Group name and group ID are mandatory parameters.
Important notes
The default limit for local UNIX groups and group members is 32768.
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
id |
integer |
UNIX group ID of the specified user. |
name |
string |
UNIX group name to be added to the local database. |
skip_name_validation |
boolean |
Indicates whether or not the validation for the specified UNIX group name is disabled. |
svm |
users |
array[users] |
Example request
"name": "group1",
"svm": {
"name": "svm1",
"users": [
"name": "string"
Status: 201, Created
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
2621706 |
The specified SVM UUID is incorrect for the specified SVM name. |
2621516 |
This operation is only supported on a data SVM. |
3277025 |
Maximum supported limit of UNIX group count reached. |
3277051 |
Invalid characters in group name. Valid characters are 0-9, A-Z, a-z, ".", "_" and "-". Names cannot start with "-". |
23724067 |
Group name too long. Maximum supported length is 64 characters. |
23724141 |
Duplicate group ID. Group ID must be unique. |
href |
string |
_links
svm
name |
string |
uuid |
string |
users
name |
string |
UNIX user who belongs to the specified UNIX group and the SVM. |
unix_group
id |
integer |
name |
string |
boolean |
svm |
users |
array[users] |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
