REST API reference
Creates the local unix group configuration for the specified svm<br/>
  • [doc /name-services/unix-groups](#docs-name-services-name-services_unix-groups)
POST /name-services/unix-groups
Introduced In: 9.9
Creates the local UNIX group configuration for the specified SVM.
Group name and group ID are mandatory parameters.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
id
integer
UNIX group ID of the specified user.
name
string
UNIX group name to be added to the local database.
skip_name_validation
boolean
Indicates whether or not the validation for the specified UNIX group name is disabled.
svm
svm
Example request
  "name": "string",
  "svm": {
    "name": "svm1",
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
2621706
The specified SVM UUID is incorrect for the specified SVM name.
3277025
Maximum supported limit of UNIX group count reached.
3277051
Invalid characters in group name. Valid characters are 0-9, A-Z, a-z, ".", "_" and "-". Names cannot start with "-".
23724067
Group name too long. Maximum supported length is 64 characters.
23724141
Duplicate group ID. Group ID must be unique.
string
svm
name
string
The name of the SVM.
uuid
string
users
name
string
UNIX user who belongs to the specified UNIX group and the SVM.
unix_group
id
integer
name
string
boolean
svm
svm
code
string
Argument code
message
string
Message argument
error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
Close
Try it out
Sign in with your NetApp Cloud Central credentials.
Try this API
Headers
Body
Code
