REST API reference
Create a local UNIX group configuration for an SVM
Creates a local UNIX group configuration for a specified SVM. Use this when you need to define group settings and identifiers to manage SVM permissions and access.
HTTP method and endpoint
POST /name-services/unix-groups
Introduced in
ONTAP 9.9
Usage notes
Group name and group ID are mandatory parameters.
Important notes
  • The default limit for local UNIX groups and group members is 32768.
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
id
integer
UNIX group ID of the specified user.
name
string
UNIX group name to be added to the local database.
skip_name_validation
boolean
Indicates whether or not the validation for the specified UNIX group name is disabled.
svm
svm
users
array[users]
Example request
  "name": "group1",
  "svm": {
    "name": "svm1",
  "users": [
      "name": "string"
Status: 201, Created
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
2621706
The specified SVM UUID is incorrect for the specified SVM name.
2621516
This operation is only supported on a data SVM.
3277025
Maximum supported limit of UNIX group count reached.
3277051
Invalid characters in group name. Valid characters are 0-9, A-Z, a-z, ".", "_" and "-". Names cannot start with "-".
23724067
Group name too long. Maximum supported length is 64 characters.
23724141
Duplicate group ID. Group ID must be unique.
string
svm
name
string
uuid
string
users
name
string
UNIX user who belongs to the specified UNIX group and the SVM.
unix_group
id
integer
name
string
boolean
svm
svm
users
array[users]
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
