Create an export policy rule client
Creates a new client for an export policy rule, specifying how the policy applies to specific NFS clients. Use this when you need to define or update access controls for a particular client in an export policy.
HTTP method and endpoint
POST /protocols/nfs/export-policies/{policy.id}/rules/{index}/clients
Introduced in
ONTAP 9.6
Usage notes
Creates an export policy rule client
Required properties
policy.id- Existing export policy that contains export policy rules for the client being added. -
index- Existing export policy rule for which to create an export client. -
match- Base name for the export policy client.
Related ONTAP commands
vserver export-policy rule add-clientmatches
Learn more
policy.id |
integer |
path |
True |
Export Policy ID |
index |
integer |
path |
True |
Export Rule Index |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
index |
integer |
Index of the rule within the export policy. |
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
policy |
svm |
Example request
"index": 0,
"match": "0.0.0.0/0",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of export rule client records |
records |
array[export_client] |
"num_records": 1,
"records": [
"index": 0,
"svm": {
"name": "svm1",
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1703954 |
Export policy does not exist |
1704036 |
Invalid clientmatch: missing domain name |
1704037 |
Invalid clientmatch: missing network name |
1704038 |
Invalid clientmatch: missing netgroup name |
1704039 |
Invalid clientmatch |
1704040 |
Invalid clientmatch: address bytes masked out by netmask are non-zero |
1704041 |
Invalid clientmatch: address bytes masked to zero by netmask |
1704042 |
Invalid clientmatch: too many bits in netmask |
1704043 |
Invalid clientmatch: invalid netmask |
1704044 |
Invalid clientmatch: invalid characters in host name |
1704045 |
Invalid clientmatch: invalid characters in domain name |
1704050 |
Invalid clientmatch: the clientmatch list contains a duplicate string. Duplicate strings in a clientmatch list are not supported |
1704054 |
Invalid clientmatch: invalid characters in netgroup name. Valid characters for a netgroup name are 0-9, A-Z, a-z, ".", "_" and "-" |
1704064 |
Clientmatch host name too long |
1704065 |
Clientmatch domain name too long |
policy
id |
integer |
Export policy ID |
href |
string |
_links
svm
name |
string |
uuid |
string |
export_client
index |
integer |
match |
string |
policy |
svm |
export_client
index |
integer |
match |
string |
policy |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
