Create an export policy rule client
Creates an export policy rule client within an existing export policy to specify client matches for access control. Use this endpoint to manage client access in your storage environment effectively.
HTTP method and endpoint
POST /protocols/nfs/export-policies/{policy.id}/rules/{index}/clients
Introduced in
ONTAP 9.6
Usage notes
Required properties
policy.id- Existing export policy that contains export policy rules for the client being added. -
index- Existing export policy rule for which to create an export client. -
match- Base name for the export policy client.
Related ONTAP commands
vserver export-policy rule add-clientmatches
Learn more
policy.id |
integer |
path |
True |
Export Policy ID |
index |
integer |
path |
True |
Export Rule Index |
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
index |
integer |
Index of the rule within the export policy. |
match |
string |
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
policy |
svm |
Example request
"index": 0,
"match": "0.0.0.0/0",
"svm": {
"name": "svm1",
Status: 201, Created
num_records |
integer |
Number of export rule client records |
records |
array[export_client] |
"records": [
"index": 0,
"svm": {
"name": "svm1",
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1703954 |
Export policy does not exist |
1704036 |
Invalid clientmatch: missing domain name |
1704037 |
Invalid clientmatch: missing network name |
1704038 |
Invalid clientmatch: missing netgroup name |
1704039 |
Invalid clientmatch |
1704040 |
Invalid clientmatch: address bytes masked out by netmask are non-zero |
1704041 |
Invalid clientmatch: address bytes masked to zero by netmask |
1704042 |
Invalid clientmatch: too many bits in netmask |
1704043 |
Invalid clientmatch: invalid netmask |
1704044 |
Invalid clientmatch: invalid characters in host name |
1704045 |
Invalid clientmatch: invalid characters in domain name |
1704050 |
Invalid clientmatch: the clientmatch list contains a duplicate string. Duplicate strings in a clientmatch list are not supported |
1704051 |
Warning: Not adding any new strings to the clientmatch field for ruleindex. All of the match strings are already in the clientmatch list |
1704064 |
Clientmatch host name too long |
1704065 |
Clientmatch domain name too long |
policy
id |
integer |
Export policy ID |
href |
string |
_links
svm
name |
string |
The name of the SVM. |
uuid |
string |
export_client
index |
integer |
match |
string |
policy |
svm |
export_client
index |
integer |
match |
string |
policy |
svm |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
