REST API reference
Create an export policy rule client
Creates an export policy rule client to define access permissions for NFS clients. This operation allows you to manage client access within a specific export policy rule.
HTTP method and endpoint
POST /protocols/nfs/export-policies/{policy.id}/rules/{index}/clients
Introduced in
ONTAP 9.6
Usage notes
Required properties
  • policy.id - Existing export policy that contains export policy rules for the client being added.
  • index - Existing export policy rule for which to create an export client.
  • match - Base name for the export policy client.
  • vserver export-policy rule add-clientmatches
policy.id
integer
path
True
Export Policy ID
index
integer
path
True
Export Rule Index
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
index
integer
Index of the rule within the export policy.
match
string
Client Match Hostname, IP Address, Netgroup, or Domain. You can specify the match as a string value in any of the following formats:
  • As a hostname; for instance, host1
  • As an IPv4 address; for instance, 10.1.12.24
  • As an IPv6 address; for instance, fd20:8b1e:b255:4071::100:1
  • As an IPv4 address with a subnet mask expressed as a number of bits; for instance, 10.1.12.0/24
  • As an IPv6 address with a subnet mask expressed as a number of bits; for instance, fd20:8b1e:b255:4071::/64
  • As an IPv4 address with a network mask; for instance, 10.1.16.0/255.255.255.0
  • As a netgroup, with the netgroup name preceded by the @ character; for instance, @eng
  • As a domain name preceded by the . character; for instance, .example.com
policy
policy
svm
svm
Example request
  "index": 0,
  "match": "0.0.0.0/0",
  "svm": {
    "name": "svm1",
Status: 201, Created
num_records
integer
Number of export rule client records
records
array[export_client]
  "num_records": 1,
  "records": [
      "index": 0,
      "svm": {
        "name": "svm1",
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
262196
Field 'svm.name' is not supported in the body of POST request
1703954
Export policy does not exist
1704036
Invalid clientmatch: missing domain name
1704037
Invalid clientmatch: missing network name
1704038
Invalid clientmatch: missing netgroup name
1704039
Invalid clientmatch
1704040
Invalid clientmatch: address bytes masked out by netmask are non-zero
1704041
Invalid clientmatch: address bytes masked to zero by netmask
1704042
Invalid clientmatch: too many bits in netmask
1704043
Invalid clientmatch: invalid netmask
1704044
Invalid clientmatch: invalid characters in host name
1704045
Invalid clientmatch: invalid characters in domain name
1704050
Invalid clientmatch: the clientmatch list contains a duplicate string. Duplicate strings in a clientmatch list are not supported
1704054
Invalid clientmatch: invalid characters in netgroup name. Valid characters for a netgroup name are 0-9, A-Z, a-z, ".", "_" and "-"
1704064
Clientmatch host name too long
1704065
Clientmatch domain name too long
6691623
User is not authorized
policy
id
integer
Export policy ID
string
svm
name
string
uuid
string
export_client
index
integer
match
string
policy
policy
svm
svm
export_client
index
integer
match
string
policy
policy
svm
svm
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
