REST API reference
Create an FC protocol service
Creates a Fibre Channel (FC) protocol service, which enables communication over a network using the FC protocol. You perform this action to set up or manage FC connections within a specified Storage Virtual Machine (SVM).
HTTP method and endpoint
POST /protocols/san/fcp/services
Introduced in
ONTAP 9.6
Usage notes
Creates an FC Protocol service.
Required properties
  • svm.uuid or svm.name - Existing SVM in which to create the FC Protocol service.
  • vserver fcp create
return_records
boolean
query
False
  • Default value:
Request Body
Name Type Description
enabled
boolean
The administrative state of the FC Protocol service. The FC Protocol service can be disabled to block all FC Protocol connectivity to the SVM.
This is optional in POST and PATCH. The default setting is true (enabled) in POST.
svm
svm
target
target
Example request
  "svm": {
    "name": "svm1",
  "target": {
    "name": "20:00:00:50:56:bb:b2:4b"
Status: 201, Created
num_records
integer
The number of records in the response.
records
array[fcp_service]
  "num_records": 1,
  "records": [
      "svm": {
        "name": "svm1",
      "target": {
Headers
Name Description Type
Location
Useful for tracking the resource location
string
Status: Default
ONTAP Error Response Codes
Error Code Description
1115127
The cluster lacks a valid FC Protocol license.
2621462
The supplied SVM does not exist.
2621507
The Fibre Channel Protocol is not allowed for the specified SVM.
2621706
The specified svm.uuid and svm.name do not refer to the same SVM.
2621707
No SVM was specified. Either svm.name or svm.uuid must be supplied.
5374082
The Fibre Channel Protocol service already exists for the SVM.
5374092
The Fibre Channel Protocol is not supported on the cluster hardware configuration; there are no Fibre Channel adapters.
5374893
The SVM is stopped. The SVM must be running to create a Fibre Channel Protocol service.
5376452
Service POST and DELETE are not supported on ASA.next.
string
iops
other
integer
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on.
read
integer
Performance metric for read I/O operations.
total
integer
Performance metric aggregated over all types of I/O operations.
write
integer
Peformance metric for write I/O operations.
latency
other
integer
read
integer
total
integer
write
integer
throughput
read
integer
total
integer
write
integer
metric
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
duration
string
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations:
iops
iops
latency
latency
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput
throughput
timestamp
string
The timestamp of the performance data.
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other
integer
read
integer
total
integer
write
integer
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other
integer
read
integer
total
integer
write
integer
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read
integer
total
integer
write
integer
statistics
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw
iops_raw
latency_raw
latency_raw
status
string
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data.
throughput_raw
throughput_raw
timestamp
string
svm
name
string
uuid
string
target
name
string
The target name of the FC Protocol service. This is generated for the SVM during POST.
The FC Protocol target name is a world wide node name (WWNN).
If required, the target name can be modified using the ONTAP command line.
  • example: 20:00:00:50:56:bb:b2:4b
  • maxLength: 128
  • minLength: 1
  • readOnly: 1
  • Introduced in: 9.6
  • x-nullable: true
fcp_service
A Fibre Channel (FC) Protocol service defines the properties of the FC Protocol target for an SVM. There can be at most one FC Protocol service for an SVM. An SVM's FC Protocol service must be created before FC Protocol initiators can login to the SVM.
A FC Protocol service is identified by the UUID of its SVM.
enabled
boolean
svm
svm
target
target
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
