Create an FC protocol service
Creates a Fibre Channel (FC) protocol service within an existing Storage Virtual Machine (SVM). This service facilitates SAN connectivity for your storage resources.
HTTP method and endpoint
POST /protocols/san/fcp/services
Introduced in
ONTAP 9.6
Usage notes
Creates an FC Protocol service.
Required properties
svm.uuidorsvm.name- Existing SVM in which to create the FC Protocol service.
Related ONTAP commands
vserver fcp create
Learn more
return_records |
boolean |
query |
False |
Request Body
| Name | Type | Description |
enabled |
boolean |
The administrative state of the FC Protocol service. The FC Protocol service can be disabled to block all FC Protocol connectivity to the SVM. This is optional in POST and PATCH. The default setting is true (enabled) in POST. |
svm |
target |
Example request
"svm": {
"name": "svm1",
"target": {
"name": "20:00:00:50:56:bb:b2:4b"
Status: 201, Created
num_records |
integer |
The number of records in the response. |
records |
array[fcp_service] |
"num_records": 1,
"records": [
"svm": {
"name": "svm1",
"target": {
Headers
| Name | Description | Type |
Location |
Useful for tracking the resource location |
string |
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
1115127 |
The cluster lacks a valid FC Protocol license. |
2621462 |
The supplied SVM does not exist. |
2621507 |
The Fibre Channel Protocol is not allowed for the specified SVM. |
2621706 |
The specified |
2621707 |
No SVM was specified. Either |
5374082 |
The Fibre Channel Protocol service already exists for the SVM. |
5374092 |
The Fibre Channel Protocol is not supported on the cluster hardware configuration; there are no Fibre Channel adapters. |
5374893 |
The SVM is stopped. The SVM must be running to create a Fibre Channel Protocol service. |
5376452 |
Service POST and DELETE are not supported on ASA r2. |
href |
string |
_links
iops
other |
integer |
Performance metric for other I/O operations. Other I/O operations can be metadata operations, such as directory lookups and so on. |
read |
integer |
Performance metric for read I/O operations. |
total |
integer |
Performance metric aggregated over all types of I/O operations. |
write |
integer |
Performance metric for write I/O operations. |
latency
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput
read |
integer |
total |
integer |
write |
integer |
metric
Performance numbers, such as IOPS latency and throughput, for SVM protocols.
duration |
string |
The duration over which this sample is calculated. The time durations are represented in the ISO-8601 standard format. Samples can be calculated over the following durations: |
iops |
The rate of I/O operations observed at the storage object. |
latency |
The round trip latency in microseconds observed at the storage object. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_ delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput |
The rate of throughput bytes per second observed at the storage object. |
timestamp |
string |
The timestamp of the performance data. |
iops_raw
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
latency_raw
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation.
other |
integer |
read |
integer |
total |
integer |
write |
integer |
throughput_raw
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time.
read |
integer |
total |
integer |
write |
integer |
statistics
These are raw performance numbers, such as IOPS latency and throughput for SVM protocols. These numbers are aggregated across all nodes in the cluster and increase with the uptime of the cluster.
iops_raw |
The number of I/O operations observed at the storage object. This should be used along with delta time to calculate the rate of I/O operations per unit of time. |
latency_raw |
The raw latency in microseconds observed at the storage object. This should be divided by the raw IOPS value to calculate the average latency per I/O operation. |
status |
string |
Any errors associated with the sample. For example, if the aggregation of data over multiple nodes fails then any of the partial errors might be returned, "ok" on success, or "error" on any internal uncategorized failure. Whenever a sample collection is missed but done at a later time, it is back filled to the previous 15 second timestamp and tagged with "backfilled_data". "Inconsistent_delta_time" is encountered when the time between two collections is not the same for all nodes. Therefore, the aggregated value might be over or under inflated. "Negative_delta" is returned when an expected monotonically increasing value has decreased in value. "Inconsistent_old_data" is returned when one or more nodes do not have the latest data. |
throughput_raw |
Throughput bytes observed at the storage object. This should be used along with delta time to calculate the rate of throughput bytes per unit of time. |
timestamp |
string |
svm
name |
string |
uuid |
string |
target
name |
string |
The target name of the FC Protocol service. This is generated for the SVM during POST. The FC Protocol target name is a world wide node name (WWNN). If required, the target name can be modified using the ONTAP command line.
fcp_service
A Fibre Channel (FC) Protocol service defines the properties of the FC Protocol target for an SVM. There can be at most one FC Protocol service for an SVM. An SVM's FC Protocol service must be created before FC Protocol initiators can login to the SVM.
A FC Protocol service is identified by the UUID of its SVM.
enabled |
boolean |
svm |
target |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
