Re-key the internal key in the key hierarchy for an SVM
Rekeys the internal key in the key hierarchy for an SVM configured with Azure Key Vault, typically to maintain security compliance or update cryptographic material.
HTTP method and endpoint
POST /security/azure-key-vaults/{uuid}/rekey-internal
Introduced in
ONTAP 9.10
Usage notes
Rekeys the internal key in the key hierarchy for an SVM with an AKV configuration.
Related ONTAP commands
security key-manager external azure rekey-internal
uuid |
string |
path |
True |
UUID of the existing AKV configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"uuid": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537120 |
Azure Key Vault is not configured for the given SVM. |
65537547 |
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation. |
65537559 |
There are no existing internal keys for the SVM. A rekey operation is allowed for an SVM with one or more encryption keys. |
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
