Re-key the internal key in the key hierarchy for an SVM
POST /security/azure-key-vaults/{azure_key_vault.uuid}/rekey-internal
Introduced In: 9.8
Rekeys the internal key in the key hierarchy for an SVM with an AKV configuration. Note: This method is only available to the Azure NetApp Files Cloud Volume Services.
Related ONTAP commands
security key-manager external azure rekey-internal
azure_key_vault.uuid |
string |
path |
True |
UUID of the existing AKV configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Status: 202, Accepted
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537120 |
Azure Key Vault is not configured for the given SVM. |
65537547 |
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation. |
65537559 |
There are no existing internal keys for the SVM. A rekey operation is allowed for an SVM with one or more encryption keys. |
| Name | Type | Description |
code |
string |
Argument code |
message |
string |
Message argument |
error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
