Re-key the internal key in the key hierarchy for an SVM
POST /security/azure-key-vaults/{uuid}/rekey-internal
Introduced In: 9.10
Rekeys the internal key in the key hierarchy for an SVM with an AKV configuration.
Related ONTAP commands
security key-manager external azure rekey-internal
uuid |
string |
path |
True |
UUID of the existing AKV configuration. |
return_timeout |
integer |
query |
False |
return_records |
boolean |
query |
False |
Status: 202, Accepted
| Name | Type | Description |
job |
"job": {
"uuid": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
| Error Code | Description |
65537120 |
Azure Key Vault is not configured for the given SVM. |
65537547 |
One or more volume encryption keys for encrypted volumes of this data SVM are stored in the key manager configured for the admin SVM. Use the REST API POST method to migrate this data SVM's keys from the admin SVM's key manager to this data SVM's key manager before running the rekey operation. |
65537559 |
There are no existing internal keys for the SVM. A rekey operation is allowed for an SVM with one or more encryption keys. |
65537610 |
Rekey cannot be performed on the SVM while the enabled keystore configuration is being switched. If a previous attempt to switch the keystore configuration failed, or was interrupted, the system will continue to prevent rekeying for the SVM. Use the REST API PATCH method "/api/security/key-stores/{uuid}" to re-run and complete the operation. |
65539436 |
Rekey cannot be performed on the SVM while the enabled keystore configuration is being initialized. Wait until the keystore is in the active state, and rerun the rekey operation. |
65539437 |
Rekey cannot be performed on the SVM while the enabled keystore configuration is being disabled. |
65539856 |
During the rekey internal operation, a restore operation failed. |
href |
string |
_links
job_link
uuid |
string |
code |
string |
Argument code |
message |
string |
Message argument |
returned_error
arguments |
array[error_arguments] |
Message arguments |
code |
string |
Error code |
message |
string |
Error message |
target |
string |
