REST API reference
Restore keys for an SVM from a configured AKV
POST /security/azure-key-vaults/{uuid}/restore
Introduced In: 9.10
Restore the keys for an SVM from a configured AKV.
  • security key-manager external azure restore
uuid
string
path
True
UUID of the existing AKV configuration.
return_timeout
integer
query
False
  • Default value: 0
  • Max value: 120
  • Min value: 0
return_records
boolean
query
False
  • Default value:
Status: 202, Accepted
Name Type Description
job
job_link
  "job": {
    "uuid": "string"
Status: 201, Created
Status: Default
ONTAP Error Response Codes
Error Code Description
65537120
Azure Key Vault is not configured for the given SVM.
65537515
Failed to restore keys on some nodes in the cluster.
65537544
Missing wrapped top-level internal key protection key (KEK) from internal database.
string
uuid
string
The UUID of the asynchronous job that is triggered by a POST, PATCH, or DELETE operation.
code
string
Argument code
message
string
Message argument
returned_error
arguments
array[error_arguments]
Message arguments
code
string
Error code
message
string
Error message
target
string
